I keep adding atleast one repository per day.! I like new stuff and to personalise my Ubuntu.
But now evertime I add a repository,the apt cache needs to be updated and its almost a 10-15min update everyday.! Moreover its a lot data consuming.
Is there any way or workaround so that the repository is updated in the apt-cache without updating other stuff?
Also,sometimes i do not wish to install some updates at the given point of time due to my bandwidth limitations.But then if i have to add a repository,the updates are all installed in the sudo apt-get update command..
Would like any help.
The bandwidth limit is actually a major issue for me.!
Thanx :)
jrg
  • 61,707
Nirmik
  • 7,938
If you don't want to get update from all the repositories at a time, uncheck them in software sources, and check them again when you really want to update from them.
https://askubuntu.com/a/27373/27559
Samik
  • 2,660
