Please I'm not a computer guy or anything am just trying to install a script by typing :
pip install -r requirements.txt
and then this error shows up twice during the process and I have no idea why :
First :
      Compile failed: command '/usr/bin/x86_64-linux-gnu-gcc' failed with exit code 1
      creating tmp
      cc -I/usr/include/libxml2 -I/usr/include/libxml2 -c /tmp/xmlXPathInitd5e8a29v.c -o tmp/xmlXPathInitd5e8a29v.o
      cc tmp/xmlXPathInitd5e8a29v.o -lxml2 -o a.out
      error: command '/usr/bin/x86_64-linux-gnu-gcc' failed with exit code 1
      [end of output]
note: This error originates from a subprocess, and is likely not a problem with pip. ERROR: Failed building wheel for lxml Running setup.py clean for lxml Failed to build lxml Installing collected packages: lxml, chardet, alabaster, urllib3, sphinxcontrib-serializinghtml, Pygments, pockets, imagesize, idna, docutils, beautifulsoup4, sphinxcontrib-websupport, sphinxcontrib-napoleon, requests, sphinx, nyawc Attempting uninstall: lxml Found existing installation: lxml 4.9.1 Not uninstalling lxml at /usr/lib/python3/dist-packages, outside environment /usr Can't uninstall 'lxml'. No files were found to uninstall. Running setup.py install for lxml ... error error: subprocess-exited-with-error
× Running setup.py install for lxml did not run successfully. │ exit code: 1
and this one at the end :
      cc -I/usr/include/libxml2 -I/usr/include/libxml2 -c /tmp/xmlXPathInitu8wuxket.c -o tmp/xmlXPathInitu8wuxket.o
      cc tmp/xmlXPathInitu8wuxket.o -lxml2 -o a.out
      [end of output]
note: This error originates from a subprocess, and is likely not a problem with pip. ERROR: Can't roll back lxml; was not uninstalled error: legacy-install-failure
× Encountered error while trying to install package. ╰─> lxml
note: This is an issue with the package mentioned above, not pip. hint: See above for output from the failure.
I assume it's something about the compiler gcc or something because I have lxml installed.
I'll appreciate the help and thank you so much in advance.
