After I've installed Ubuntu 22.10, Windows 10 doesn't boot from GRUB (the computer just reboots). My computer has a BIOS motherboard that doesn't support UEFI.
The Ubuntu installer couldn't automatically partition my drive because it already had 4 partitions (MBR limit).
I've prepared my drive for partitioning the following way:
- Shrinked sda2
- Moved sda3 and sda4 just after sda2
- Converted the MBR to GPT using
gdisk -f - Ran the Ubuntu installation, chosing "Install alongside Windows 10"
Current drive partitions (fdisk -l):
Disk /dev/sda: 931,51 GiB, 1000204886016 bytes, 1953525168 sectors
Disk model: Samsung SSD 850
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: gpt
Disk identifier: 283EE3B5-B530-4F2E-9FB2-149FB9A724D7
Device Start End Sectors Size Type
/dev/sda1 2048 206847 204800 100M Microsoft basic data
/dev/sda2 206848 1644306431 1644099584 784G Microsoft basic data
/dev/sda3 1644306432 1645398015 1091584 533M Windows recovery environment
/dev/sda4 1645398016 1646319615 921600 450M Windows recovery environment
/dev/sda5 1646319616 1646321663 2048 1M BIOS boot
/dev/sda6 1646321664 1647372287 1050624 513M EFI System
/dev/sda7 1647372288 1953523711 306151424 146G Linux filesystem
Disk /dev/sdb: 10,91 TiB, 12000138625024 bytes, 23437770752 sectors
Disk model: ST12000VN0008-2Y
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: gpt
Disk identifier: C984BE76-DC83-4A2C-99DF-6F27D46768B1
/dev/sdb1 34 32767 32734 16M Microsoft reserved
/dev/sdb2 32768 23437766655 23437733888 10,9T Microsoft basic data
Things I've tried to fix the problem:
- Added
ntldr /bootmgrat the end of the Windows menu entry in grub.cfg - Used boot-repair as described here
- Ran update-grub.
None of those worked.
Things I don't want to do: reinstall Windows 10.
Please help.
