I have a System76 Gazelle laptop running Ubuntu 22.04. I tried to setup Ubuntu Pro, but it always shows the error, An error occurred when checking for Livepatch updates. While troubleshooting this I noticed that the pro command was giving me the error WARNING:root:failed to process /proc/version_signature.
➜ ~ sudo pro status
SERVICE ENTITLED STATUS DESCRIPTION
esm-infra yes enabled Expanded Security Maintenance for Infrastructure
livepatch yes enabled Canonical Livepatch service
realtime-kernel yes disabled Ubuntu kernel with PREEMPT_RT patches integrated
Enable services with: pro enable <service>
Account: ___@___.___
Subscription: Ubuntu Pro - free personal subscription
Sure enough, this file is missing.
➜ ~ cat /proc/version_signature
cat: /proc/version_signature: No such file or directory
I haven't done any real extreme customization on this machine, like trying to use a custom kernel, so I'm not sure why this file would be missing. Any thoughts on how I can recover this file?
Edit:
uname -r shows that I was running kernel 6.0.6. I switched to 5.15.0 in the grub menu, and now /proc/version_signature is available.
Ubuntu 5.15.0-56.62-generic 5.15.64
I'm not certain why the 6.0 kernel is installed. An identical laptop has kernel 5.15. Attempts to uninstall the 6.0.x kernel wants to uninstall important packages.
➜ ~ sudo apt remove linux-image-6.0.6-76060006-generic
Reading package lists... Done
Building dependency tree... Done
The following packages were automatically installed and are no longer required:
amd-ppt-bin at dfu-programmer firmware-manager firmware-manager-notify firmware-manager-shared gnome-shell-extension-system76-power hidpi-daemon linux-headers-6.0.2-76060002
linux-headers-6.0.2-76060002-generic linux-image-6.0.2-76060002-generic linux-modules-6.0.2-76060002-generic python3-evdev python3-pydbus system76-acpi-dkms system76-dkms system76-firmware-daemon
system76-io-dkms system76-oled system76-power system76-wallpapers xbacklight
Use 'sudo apt autoremove' to remove them.
The following packages will be REMOVED:
linux-generic linux-image-6.0.6-76060006-generic linux-image-generic linux-system76 system76-driver system76-driver-nvidia
0 upgraded, 0 newly installed, 6 to remove and 0 not upgraded.
After this operation, 12.6 MB disk space will be freed.
Do you want to continue? [Y/n]
