What can I do to normally update my system (Ubuntu). By acident I shutdown my PC while updating a linux-kernel package, also I think at time of update my Ubuntu start to updating from old 18 vesion to 22 version. I tried this command, but have no result:
sudo apt --fix-broken install
sudo apt-get upgrade -f
sudo dpkg --configure -a
>>> sudo apt upgrade
Reading package lists... Done
Building dependency tree... Done
You might want to run 'apt --fix-broken install' to correct these.
 duplicity : Depends: python3 (>= 3.10~) but 3.8.2-0ubuntu2 is installed
 hplip : Depends: python3 (>= 3.10~) but 3.8.2-0ubuntu2 is installed
 kitty : Depends: python3 (>= 3.10~) but 3.8.2-0ubuntu2 is installed
 liblocale-gettext-perl : PreDepends: perlapi-5.30.0 but it is not installable
 python2 : PreDepends: python2-minimal (= 2.7.17-2ubuntu4) but 2.7.18-3 is installed
           Depends: libpython2-stdlib (= 2.7.17-2ubuntu4) but 2.7.18-3 is installed
 python3 : PreDepends: python3-minimal (= 3.8.2-0ubuntu2) but 3.10.6-1~22.04 is installed
           Depends: libpython3-stdlib (= 3.8.2-0ubuntu2) but 3.10.6-1~22.04 is installed
 python3-apt : Depends: python3 (>= 3.10~) but 3.8.2-0ubuntu2 is installed
 python3-brlapi : Depends: python3 (>= 3.10~) but 3.8.2-0ubuntu2 is installed
 python3-cairo : Depends: python3 (>= 3.10~) but 3.8.2-0ubuntu2 is installed
 python3-cffi-backend : Depends: python3 (>= 3.10~) but 3.8.2-0ubuntu2 is installed
 python3-cups : Depends: python3 (>= 3.10~) but 3.8.2-0ubuntu2 is installed
 python3-dbus : Depends: python3 (>= 3.10~) but 3.8.2-0ubuntu2 is installed
 python3-dev : Depends: python3 (= 3.10.6-1~22.04) but 3.8.2-0ubuntu2 is installed
               Breaks: python3 (< 3.9.2-1~) but 3.8.2-0ubuntu2 is installed
 python3-distutils : Depends: python3:any (>= 3.10.5-0~)
 python3-gdbm : Depends: python3 (>= 3.10.5-0~) but 3.8.2-0ubuntu2 is installed
 python3-gi : Depends: python3 (>= 3.10~) but 3.8.2-0ubuntu2 is installed
 python3-gi-cairo : Depends: python3 (>= 3.10~) but 3.8.2-0ubuntu2 is installed
 python3-greenlet : Depends: python3 (>= 3.10~) but 3.8.2-0ubuntu2 is installed
 python3-ldb : Depends: python3 (>= 3.10~) but 3.8.2-0ubuntu2 is installed
 python3-lib2to3 : Depends: python3:any (>= 3.10.5-0~)
 python3-markupsafe : Depends: python3 (>= 3.10~) but 3.8.2-0ubuntu2 is installed
 python3-msgpack : Depends: python3 (>= 3.10~) but 3.8.2-0ubuntu2 is installed
 python3-netifaces : Depends: python3 (>= 3.10~) but 3.8.2-0ubuntu2 is installed
 python3-pil : Depends: python3 (>= 3.10~) but 3.8.2-0ubuntu2 is installed
 python3-protobuf : Depends: python3 (>= 3.10~) but 3.8.2-0ubuntu2 is installed
 python3-pyqt5.sip : Depends: python3 (>= 3.10~) but 3.8.2-0ubuntu2 is installed
 python3-renderpm : Depends: python3 (>= 3.10~) but 3.8.2-0ubuntu2 is installed
 python3-reportlab-accel : Depends: python3 (>= 3.10~) but 3.8.2-0ubuntu2 is installed
 python3-simplejson : Depends: python3 (>= 3.10~) but 3.8.2-0ubuntu2 is installed
 python3-sip : Depends: python3 (>= 3.10~) but 3.8.2-0ubuntu2 is installed
 python3-systemd : Depends: python3 (>= 3.10~) but 3.8.2-0ubuntu2 is installed
 python3-talloc : Depends: python3 (>= 3.10~) but 3.8.2-0ubuntu2 is installed
 python3-uno : Depends: python3 (>= 3.10~) but 3.8.2-0ubuntu2 is installed
 python3-yaml : Depends: python3 (>= 3.10~) but 3.8.2-0ubuntu2 is installed
 rhythmbox-plugins : Depends: python3 (>= 3.10~) but 3.8.2-0ubuntu2 is installed
 usb-creator-gtk : Depends: usb-creator-common (= 0.3.13) but 0.3.7 is installed
 virtualbox : Depends: python3 (>= 3.10~) but 3.8.2-0ubuntu2 is installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
>>> sudo apt --fix-broken install Reading package lists... Done Building dependency tree... Done Reading state information... Done Correcting dependencies... Done The following packages were automatically installed and are no longer required: app-install-data-partner bsdmainutils ca-certificates-java clangd-10 default-jre default-jre-headless fonts-dejavu-extra g++-9 gcc-10-base gir1.2-clutter-gst-3.0 gir1.2-gnomebluetooth-1.0 gir1.2-gtkclutter-1.0 gir1.2-handy-0.0 gnome-getting-started-docs gnome-screenshot icu-devtools java-common ldap-utils libamtk-5-0 libamtk-5-common libaom0 libatk-wrapper-java libatk-wrapper-java-jni libboost-date-time1.71.0 libboost-filesystem1.71.0 libboost-iostreams1.71.0 libboost-locale1.71.0 libboost-thread1.71.0 libcamel-1.2-62 libcbor0.6 libcdio18 libcmis-0.5-5v5 libcodec2-0.9 libdecor-0-0 libdecor-0-plugin-1-cairo libdns-export1109 libedataserver-1.2-24 libedataserverui-1.2-2 libextutils-pkgconfig-perl libgnome-bg-4-1 libgsoap-2.8.91 libgupnp-1.2-0 libhogweed5 libicu-dev libidn11 libigdgmm11 libilmbase24 libisl22 libjson-c4 libjsoncpp1 libjuh-java libjurt-java liblibreoffice-java liblldb-14 libmozjs-68-0 libmysqlclient21 libneon27-gnutls libnettle7 libnfsidmap1 libntfs-3g883 libopenexr24 liborcus-0.15-0 libpam-pwquality libperl5.30 libphonenumber7 libpoppler97 libprotobuf17 libpython3.8-dev libqpdf26 libreoffice-style-tango libridl-java libsdl2-2.0-0 libsnmp35 libtcl8.6 libtepl-4-0 libtracker-control-2.0-0 libtracker-miner-2.0-0 libtracker-sparql-2.0-0 libunoloader-java libvpx6 libx264-155 libx265-179 libxml2-dev ltrace lz4 mysql-common ncal openjdk-11-jre openjdk-11-jre-headless perl-modules-5.30 pkg-config popularity-contest python3-entrypoints python3-neovim python3-packaging python3-requests-unixsocket python3-simplejson python3-sip python3.8 python3.8-dev python3.8-minimal syslinux syslinux-common syslinux-legacy ure-java vino xul-ext-ubufox Use 'sudo apt autoremove' to remove them. The following additional packages will be installed: liblocale-gettext-perl linux-image-5.15.0-56-generic python2 python3 usb-creator-common Suggested packages: fdutils linux-doc | linux-source-5.15.0 linux-tools python2-doc python-tk python3-doc python3-tk python3-venv The following packages will be upgraded: liblocale-gettext-perl linux-image-5.15.0-56-generic python2 python3 usb-creator-common 5 upgraded, 0 newly installed, 0 to remove and 113 not upgraded. 1347 not fully installed or removed. Need to get 0 B/11.5 MB of archives. After this operation, 60.4 kB disk space will be freed. Do you want to continue? [Y/n] Y Setting up dpkg (1.21.1ubuntu2.1) ... head: error reading 'dpkg': Is a directory dpkg: error processing package dpkg (--configure): installed dpkg package post-installation script subprocess returned error exit status 1 dpkg: dependency problems prevent configuration of perl-base: perl-base depends on dpkg (>= 1.17.17); however: Package dpkg is not configured yet.
dpkg: error processing package perl-base (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of python3-minimal: python3-minimal depends on dpkg (>= 1.13.20); however: Package dpkg is not configured yet.
dpkg: error processing package python3-minimal (--configure): dependency problems - leaving unconfigured No apport report written because the error message indicates its a followup erro r from a previous failure. No apport report written because the error message ind icates its a followup error from a previous failure. Errors were encountered whil e processing: dpkg perl-base python3-minimal E: Sub-process /usr/bin/dpkg returned an error code (1)
>>> sudo apt-get upgrade -f ......................... head: error reading 'dpkg': Is a directory dpkg: error processing package dpkg (--configure): installed dpkg package post-installation script subprocess returned error exit status 1 dpkg: dependency problems prevent configuration of perl-base: perl-base depends on dpkg (>= 1.17.17); however: Package dpkg is not configured yet.
dpkg: error processing package python3-minimal (--configure): dependency problems - leaving unconfigured No apport report written because the error message indicates its a followup error from a previous failure. No apport report written because the error message indicates its a followup error from a previous failure. Errors were encountered while processing: dpkg perl-base python3-minimal E: Sub-process /usr/bin/dpkg returned an error code (1)
>>> sudo dpkg --configure -a ........ dpkg: error processing package {PACKAGE_NAME} (--configure): dependency problems - leaving unconfigured ......... dpkg: too many errors, stopping Errors were encountered while processing: python3-distutils hplip python3-dbus system-config-printer-common python3-cairo:amd64 python3-renderpm:amd64 python3-setuptools usb-creator-gtk python3-gdbm:amd64 python3-talloc:amd64 python3-apt python3-aptdaemon update-notifier-common rhythmbox-plugins update-manager samba-libs:amd64 python3-yaml kitty python3 linux-modules-5.15.0-56-generic python3-zipp python3-click python3-xdg python3-distupgrade python3-markupsafe printer-driver-postscript-hp openprinting-ppds software-properties-common apport python3-tz python3-cliapp python3-apport netplan.io python3-cupshelpers python3-six python3-simplejson ibus-table python3-pil:amd64 python3-cups:amd64 python3-oauthlib python3-chardet python3-secretstorage python3-pyparsing python3-software-properties system-config-printer python3-certifi gnome-tweaks python3-pexpect python3-cryptography python3-wadllib Processing was halted because there were too many errors.
>>> cat /etc/apt/sources.list
deb cdrom:[Ubuntu 20.04.5 LTS Focal Fossa - Release amd64 (20220831)]/ focal main restricted
See http://help.ubuntu.com/community/UpgradeNotes for how to upgrade to
newer versions of the distribution.
deb http://ua.archive.ubuntu.com/ubuntu/ jammy main restricted
deb-src http://ua.archive.ubuntu.com/ubuntu/ focal main restricted
Major bug fix updates produced after the final release of the
distribution.
deb http://ua.archive.ubuntu.com/ubuntu/ jammy-updates main restricted
deb-src http://ua.archive.ubuntu.com/ubuntu/ focal-updates main restricted
N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
team. Also, please note that software in universe WILL NOT receive any
review or updates from the Ubuntu security team.
deb http://ua.archive.ubuntu.com/ubuntu/ jammy universe
deb-src http://ua.archive.ubuntu.com/ubuntu/ focal universe
deb http://ua.archive.ubuntu.com/ubuntu/ jammy-updates universe
deb-src http://ua.archive.ubuntu.com/ubuntu/ focal-updates universe
team, and may not be under a free licence. Please satisfy yourself as to
your rights to use the software. Also, please note that software in
multiverse WILL NOT receive any review or updates from the Ubuntu
security team.
deb http://ua.archive.ubuntu.com/ubuntu/ jammy multiverse
deb-src http://ua.archive.ubuntu.com/ubuntu/ focal multiverse
deb http://ua.archive.ubuntu.com/ubuntu/ jammy-updates multiverse
deb-src http://ua.archive.ubuntu.com/ubuntu/ focal-updates multiverse
N.B. software from this repository may not have been tested as
extensively as that contained in the main release, although it includes
newer versions of some applications which may provide useful features.
Also, please note that software in backports WILL NOT receive any review
deb http://ua.archive.ubuntu.com/ubuntu/ jammy-backports main restricted universe multiverse
deb-src http://ua.archive.ubuntu.com/ubuntu/ focal-backports main restricted universe multiverse
deb http://security.ubuntu.com/ubuntu jammy-security main restricted
deb-src http://security.ubuntu.com/ubuntu focal-security main restricted
deb http://security.ubuntu.com/ubuntu jammy-security universe
deb-src http://security.ubuntu.com/ubuntu focal-security universe
deb http://security.ubuntu.com/ubuntu jammy-security multiverse
deb-src http://security.ubuntu.com/ubuntu focal-security multiverse
This system was installed using small removable media
(e.g. netinst, live or single CD). The matching "deb cdrom"
entries were disabled at the end of the installation process.
For information about how to configure apt package sources,
see the sources.list(5) manual.
