I recently went to update my system (Ubuntu Studio 22.10) and new Linux Kernels were available. On Ubuntu Studio you receive updates for both the generic and low latency kernels, with the low latency being the one you boot too.
Well something has clearly gone wrong with this, as it fails to install the updated kernels (both of them) and now I can't install or update any of my packages using apt (luckily snap and flatpak still works).
I am currently stuck on kernel low latency 1009, when 1012 is available.
I've seen some questions similar to this but none can provide me with a solution.
Neither Sudo apt-get install -f nor sudo apt --fix-broken install work.
My system seems to want me to remove linux-image-5.19.0-23-generic but any attempt to remove this package fails, and tells me that dpkg has ran into too many errors.
When attempting to remove the package through Synaptic all I got was this:
E: linux-image-5.19.0-23-generic: installed linux-image-5.19.0-23-generic package post-removal script subprocess returned error exit status 1
It might also be useful to note that this install of Ubuntu started at 21.10 and has been upgraded through 22.04 and 22.10. I would really rather not have to reinstall my entire system. So please say there is a way to fix this.
I'll be glad to provide more info if needed.
Thank you in advance!
Edit: here is the output of apt -f install
Reading package lists... Done
Building dependency tree... Done
The following packages will be REMOVED
0 to upgrade, 0 to newly install, 1 to remove and 2 not to upgrade.
3 not fully installed or removed.
After this operation, 12.2 MB disk space will be freed.
Do you want to continue? [Y/n] y
(Reading database ... 406974 files and directories currently installed.)
Removing linux-image-5.19.0-23-generic (5.19.0-23.24) ...
/etc/kernel/postrm.d/initramfs-tools:
update-initramfs: Deleting /boot/initrd.img-5.19.0-23-generic
/etc/kernel/postrm.d/zz-update-grub:
Sourcing file `/etc/default/grub'
Sourcing file `/etc/default/grub.d/init-select.cfg'
Generating grub configuration file ...
/etc/grub.d/bin/grubcfg_proxy: error while loading shared libraries: libcrypto.so.1.1: cannot open shared object file: No such file or directory
run-parts: /etc/kernel/postrm.d/zz-update-grub exited with return code 127
dpkg: error processing package linux-image-5.19.0-23-generic (--remove):
dpkg: too many errors, stopping
Processing was halted because there were too many errors.
guiverc
  • 33,561
AdLinux
  • 526
  • 26
Currently you cannot do much except install the libcrypto.so.1.1 which is an deprecated version like this.
the origin of the problem is the grub script grub_proxy, it is not from any official packages. It must come from your own modification or from some ppa.
Please try:
apt-file find grubcfg_proxy
If you have apt-file. Identify that package and uninstall it. Then try to find alternative to it. I guess you are using grub-customizer. When you use some ppa change your boot process and then use do-release-upgrade is basically shooting yourself in the foot. Because, do-release-upgrade will try to mask out all customized repos. However, boot process definitely depends on those masked out packages to function. Moreover, the old packages on the system usually depend on system libraries accurately to specific subversions. So in most cases the old packages won't work at all. Most users do not notice this, since they are not using boot-process-customizers. After reboot into new version, the broken packages can be upgraded by enable the ppa of new release version or uninstalled and replaced by alternative packages.
To me, the release upgrade never works (more than 20 year experience. I try the release upgrade method every time I saw it, never works.). I highly recommend you reinstall your system regularly. You have to be smart to keep your /home on a different partition and do not format or overwrite it during installation. After installation, you can try out fresh system to see if you like it. Then modify /etc/fstab to mount your /home partition back. Then you can see if there is some config in your ~ you have to modify (usually only small portion of them need to be changed/recreated).
You can check how many mess the release-upgrade had created via running aptitude search '?narrow(?installed, ~o)'. This gives you the orphan packages usually a source of broken dependencies.
Reinstall ubuntu only take about 10 mins, so no real reason to not do it if you do not perform deep customization: (adding too many ppas, change too much boot configuration, use more than twice update-alternatives). If you do lots of customization then you wish not touch the configurations. However, the configure files change formats, the packages come and go. Thus, if you wish to not touch the configuration, you end up cannot upgrade at all: the release update will destroy your system. This is hard lesson I learned at the very beginning and it remains true. So I highly recommand you only do user customization with configs in your ~/. Only touch very small set of configuration in /etc and use some sysop tools like ansible to maintain it, if you feel you still touched too many parts of the system and need to automate it. If you do not know what ansible is and do not want to learn it. Then I suggest you choose the best distro fit you out-of-box. Do NOT tweak the system to make it your own distro, it is missing impossible. You have to ask yourself if you hate most of the default settings why you are still using this distro at all.
Wang
  • 725
-1
Found a simple solution...
My grub was failing to boot in low latency, due to the last full upgrade didn't install the low latency images...
So I tried to fix this... Rebbot in recovery mode, and activate network... Go to root command line, and run apt or apt-get, update and make a full upgrade system... Currently not installing any image file... Reboot again check if you have any low-latency for the latest kernel to boot, if you don't have... reboot on the last low-latency image available. In my case it is 5.6.2-low latency, and do the same Wich I'm doing right now... It seems it is an error loading the low -latency images...
It happens when the system installed Ubuntu 5.15.0-60 update, it missed the low latency images and headers...
Solution:::::
Load up the latest generic image in recovery mode. Active network Go root command line Run apt-get or apt update Run apt install linux-image-(your image number)-lowlatency Example: apt-get install linux-image-5.15.0-60-lowlatency
Then install headers apt-get install linux-headers-5.15.0-60-lowlatency
Reboot
It will be fixed...
Thank you guys...
