i am currently trying to do-release-upgrade an Ubuntu 17.10 install to 18.04.6 LTS via 'sudo do-release-upgrade'. Sadly, the process does not finish, as it return the following very quickly:
(appstreamcli:26495): GLib-CRITICAL **: g_variant_builder_end: assertion '!GVSB(builder)->uniform_item_types || GVSB(builder)->prev_item_type != NULL || g_variant_type_is_definite (GVSB(builder)->type)' failed
(appstreamcli:26495): GLib-CRITICAL **: g_variant_new_variant: assertion 'value != NULL' failed
(appstreamcli:26495): GLib-ERROR **: g_variant_new_parsed: 11-13:invalid GVariant format string
Trace/breakpoint trap (core dumped)
Fehler während der Aktualisierung
Bei der Aktualisierung trat ein Problem auf. Dies ist häufig auf
Netzwerkprobleme zurückzuführen. Bitte überprüfen Sie Ihre
Netzwerkverbindung und versuchen Sie es erneut.
E:Problem executing scripts APT::Update::Post-Invoke-Success 'if
/usr/bin/test -w /var/cache/app-info -a -e /usr/bin/appstreamcli;
then appstreamcli refresh-cache > /dev/null; fi', E:Sub-process
returned an error code
Having stumbled upon similar questions, i tried to reinstall and even purge appstreamcli and libappstream4, however to no avail. Interestingly, both sudo apt-get upgrade and sudo apt-get upgrade work without problems (although no more upgrades can be found due to the end-of-support I guess).
Here is also the output from
sudo apt-show-versions appstream
appstream:amd64 not installed
appstream:i386 not installed
and
sudo apt-show-versions libappstream4
libappstream4:amd64/artful 0.11.3-1 uptodate
libappstream4:i386 not installed
Happy to here your thoughts on how to tackle this - thanks in advance!
Edit: Here is my login screen, prompting me to do-release-upgrade screenshot
