I tried to upgrade my system, but I got this error messages:
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
# News about significant security updates, features and services will
# appear here to raise awareness and perhaps tease /r/Linux ;)
# Use 'pro config set apt_news=false' to hide this and future APT news.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
3 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Setting up nvidia-dkms-470 (470.161.03-0ubuntu0.20.04.1) ...
update-initramfs: deferring update (trigger activated)
update-initramfs: Generating /boot/initrd.img-5.15.0-56-generic
INFO:Enable nvidia
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/put_your_quirks_here
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/lenovo_thinkpad
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/dell_latitude
Removing old nvidia-470.161.03 DKMS files...
-------- Uninstall Beginning -------- Module: nvidia Version: 470.161.03 Kernel: 5.15.0-56-generic (x86_64)
Status: Before uninstall, this module version was ACTIVE on this kernel.
nvidia.ko:
  • Uninstallation
    • Deleting from: /lib/modules/5.15.0-56-generic/updates/dkms/
  • Original module
    • No original module was found for this module on this kernel.
    • Use the dkms install command to reinstall any previous module version.
nvidia-modeset.ko:
  • Uninstallation
  • Original module
nvidia-drm.ko:
  • Uninstallation
  • Original module
nvidia-uvm.ko:
  • Uninstallation
  • Original module
nvidia-peermem.ko:
  • Uninstallation
  • Original module
depmod...
DKMS: uninstall completed.
Deleting module version: 470.161.03 completely from the DKMS tree.
Done. Loading new nvidia-470.161.03 DKMS files... Building for 5.15.0-56-generic 6.0.12-x64v1-xanmod1 Building for architecture x86_64 Building initial module for 5.15.0-56-generic Secure Boot not enabled on this system. Done.
nvidia.ko: Running module version sanity check.
  • Original module
    • No original module exists within this kernel
  • Installation
    • Installing to /lib/modules/5.15.0-56-generic/updates/dkms/
nvidia-modeset.ko: Running module version sanity check.
  • Original module
  • Installation
nvidia-drm.ko: Running module version sanity check.
  • Original module
  • Installation
nvidia-uvm.ko: Running module version sanity check.
  • Original module
  • Installation
nvidia-peermem.ko: Running module version sanity check.
  • Original module
  • Installation
depmod...
DKMS: install completed. Building initial module for 6.0.12-x64v1-xanmod1 ERROR (dkms apport): kernel package linux-headers-6.0.12-x64v1-xanmod1 is not supported Error! Bad return status for module build on kernel: 6.0.12-x64v1-xanmod1 (x86_64) Consult /var/lib/dkms/nvidia/470.161.03/build/make.log for more information. dpkg: error processing package nvidia-dkms-470 (--configure): installed nvidia-dkms-470 package post-installation script subprocess returned error exit status 10 dpkg: dependency problems prevent configuration of nvidia-driver-470: nvidia-driver-470 depends on nvidia-dkms-470 (<= 470.161.03-1); however: Package nvidia-dkms-470 is not configured yet. nvidia-driver-470 depends on nvidia-dkms-470 (>= 470.161.03); however: Package nvidia-dkms-470 is not configured yet.
dpkg: error processing package nvidia-driver-470 (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of nvidia-driver-460: nvidia-driver-460 depends on nvidia-driver-470; however: Package nvidia-driver-470 is not configured yet.
dpkg: error processing package nvidia-driver-460 (--configure): dependency problems - leaving unconfigured No apport report written because the error message indicates its a followup error from a previous failure. No apport report written because the error message in dicates its a followup error from a previous failure. Processing triggers for initramfs-tools (0.136ubuntu6.7) ... update-initramfs: Generating /boot/initrd.img-6.0.12-x64v1-xanmod1 Errors were encountered while processing: nvidia-dkms-470 nvidia-driver-470 nvidia-driver-460 E: Sub-process /usr/bin/dpkg returned an error code (1)
It seems that latest nvidia drivers aren't compatible with xanmod1 kernel, so I tried upgrading from generic kernel but got the same result.
Any way to upgrade or disable this messages when upgrading? My system info:
key value
os Ubuntu 20.04.5 LTS x86_64
host HP Pavilion Laptop 15-cs3xxx
kernel 5.15.0-56-generic
uptime 21min 34sec
dpkgPackages 3797
snapPackages 12
shell nu 0.72.2
resolution 1920x1080
de ubuntu:GNOME
theme Black-n-White-GTK
icons suru-plus-aspromauros-1.6
terminal terminal
cpu Intel(R) Core(TM) i7-1065G7 CPU @ 1.30GHz
cores 4
gpu [Intel Corporation Iris Plus Graphics G7 (rev 07) 00:02.0, NVIDIA Corporation GP107M [GeForce GTX 1050 3 GB Max-Q] (rev a1) 06:00.0]
disk 341.7 GB / 490.6 GB
memory 6.7 GB / 12.3 GB
