I have an old HP ProBook laptop computer, purchased August 2014. While the hardware still works fine after all years, I run into problems with the OS, which is Windows 7 - no longer supported by Microsoft. Instead of trying to obtain and install a newer Win version, I am considering to try Ubuntu. Do you think that Ubuntu will work on this old PC?
That depends on your hardware specs. According to official Ubuntu documentation there is a good "rule of thumb". Which is that machines that could run XP, Vista, Windows 7 or x86 OS X will almost always be a lot faster with Ubuntu even if they are lower-spec than described below.
2 GHz dual core processor
4 GiB RAM (system memory)
25 GB (8.6 GB for minimal) of hard-drive space (or USB stick, memory card or external drive but see LiveCD for an alternative approach)
VGA capable of 1024x768 screen resolution
Either a CD/DVD drive or a USB port for the installer
Still, if your old computer does not have those required hardware specs, you can opt for lighter flavors of Ubuntu, such as Xubuntu or Lubuntu. The most lightweight distro that I can think of is Lubuntu, which uses LXQt desktop environment, not the prettiest but will run almost everywhere. Another cool flavor of Ubuntu is Kubuntu, not as lightweight as the other two, but really good looking. Check them out.
- 470
Check the hardware requirements here https://ubuntu.com/download/desktop then give it a try, mostly it will work.
- 61
