13
so I wanted to install firefox in WSL2 with Ubuntu. Now, using
sudo apt install firefox
gives me this output:
Building dependency tree... Done
The following NEW packages will be installed:
  firefox
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 72.3 kB of archives.
After this operation, 261 kB of additional disk space will be used.
Get:1 http://archive.ubuntu.com/ubuntu jammy/main amd64 firefox amd64 1:1snap1-0ubuntu2 [72.3 kB]
Fetched 72.3 kB in 0s (420 kB/s)
Preconfiguring packages ...
Selecting previously unselected package firefox.
(Reading database ... 24109 files and directories currently installed.)
Preparing to unpack .../firefox_1%3a1snap1-0ubuntu2_amd64.deb ...
=> Installing the firefox snap
==> Checking connectivity with the snap store
===> System doesn't have a working snapd, skipping
Unpacking firefox (1:1snap1-0ubuntu2) ...
Setting up firefox (1:1snap1-0ubuntu2) ...
update-alternatives: using /usr/bin/firefox to provide /usr/bin/gnome-www-browser (gnome-www-browser) in auto mode
update-alternatives: using /usr/bin/firefox to provide /usr/bin/x-www-browser (x-www-browser) in auto mode
Trying to launch firefox at this point will fail:
Command '/usr/bin/firefox' requires the firefox snap to be installed.
Please install it with:
snap install firefox
Once I run said snap command, I get this:
error: cannot communicate with server: Post "http://localhost/v2/snaps/firefox": dial unix /run/snapd.socket: connect: no such file or directory
Can anyone help me with this? I'm not a linux expert.
muru
  • 207,228
LightJack05
  • 667
  • 13
Quick answer:
Use your browser and look at:
https://ubuntuhandbook.org/index.php/2022/04/install-firefox-deb-ubuntu-22-04/
It says, in short (you might need to skip the first two if you already did those):
sudo snap remove firefox
sudo apt remove firefox
sudo add-apt-repository ppa:mozillateam/ppa
Create a new file, it should be empty as it opens:
sudo gedit /etc/apt/preferences.d/mozillateamppa
Insert these lines, then save and exit
Package: firefox* Pin: release o=LP-PPA-mozillateam Pin-Priority: 501
after saving, do
sudo apt update sudo apt install firefox # or firefox-esr
Hannu
  • 6,605
  • 28
  • 45
10
It looks like you may either:
  • Be on an older WSL2 release
  • Or haven't enabled Systemd on WSL2
Snap is now supported on Ubuntu on WSL2 by enabling the Systemd functionality as mentioned in my answer here.
However, consider whether you truly need this:
  • As mentioned in my answer there, enabling Systemd will create additional overhead that isn't always needed.
  • The Windows version of Firefox may be a better option (unless you truly need to test some Firefox functionality that is specific to Ubuntu or Linux-in-general).
  • The PPA mentioned in the other answer is a valid alternative as well.
NotTheDr01ds
  • 22,082
