I'm running Ubuntu 22.04.1 LTS, and I'm not sure how to point the calendar at my CalDAV server. I'm using Baïkal as my CalDAV server. The calendar application has no settings dialog, but only directs the user to the Online Accounts settings page (see screenshot below). The problem is that "CalDAV" isn't a choice, and I don't want to use a Google, Microsoft Exchange, etc. calendar.
Another problem is that the calendar pops up a dialog titled "Authentication request", requesting the password for an account with an obsolete user name. I did a fresh install of this Ubuntu version rather than an upgrade, so the calendar must be getting the obsolete setting from an old configuration file that was copied over. The calendar is populated with old events, so those must have been from a stale hidden file that was copied over also. So in addition to pointing the calendar to my server, I also need to clear out the old and inaccurate setting pointing to a nonexistent server (probably my old ownCloud server).
Screenshot of the Ubuntu 22.04 Online Accounts settings page, scaled down a bit
rclocher3
  • 789
From what I'm seeing, you may want to try using Evolution to get this set up, and purportedly you can uninstall it after. As for the other problem, the easiest thing would be to purge gnome-calendar then reinstall it, no?
Julian
  • 180
Or even better:
  • go to "manage calendars" (middle icon on the top right)
  • and there "add new calendar" screenshot
  • In the bottom field it looks, like you can only enter ics files. But there you can also enter the link to your caldav-calendar.
Leon
