Software Updater loaded in an -oracle flavour kernel, on which no network works. I've used Grub to set the previous, working kernel as the default.
How do I remove the -oracle kernel, 1a. maybe even get the previous working kernel as a back up so that updater will provide only -generic kernels going forward? I've read How to downgrade kernel after bad update (16.04) and the solution there changed to:
sudo apt remove linux-image-5.15.0-1025-oracle linux-headers-5.15.0-1025-oracle
But it may or may not be the up-to-date answer for this? I'm hesitant to try without wiser heads knowing it is a good step.
Software Updater says everything is up to date. I've reported a bug, no action on the bug report yet. BIOS boots to a NOT EFI, I've tried to force the EFI but it reverts no matter what I try, one time override, disabling those entries, though I have not totally deleted those entries (2 of them are identical an not EFI) running ZFS on the boot drive. hwmatch error showed up after setting the default by setting
GRUB_DEFAULT=saved
GRUB_SAVEDEFAULT=true
and then updating grub.
I added the explicit insmod hwmatch
Which took care of that error, or at least it is not displayed on boot anymore.
(or am I completely missing something about -oracle or kernels in general? I am just a 'private' afterall.-:)
