I was using the following link as a reference to switch over from pulseaudio to pipewire. https://gist.github.com/the-spyke/2de98b22ff4f978ebf0650c90e82027e?permalink_comment_id=3976215
The reason I was looking to switch over is that I've been experiencing all kinds of problems with my bluetooth headsets and I read that pipewire resolved a lot of the issues with bluetooth.
sudo apt install \
libspa-0.2-bluetooth \
pipewire-audio-client-libraries \
pipewire-media-session- \
wireplumber
Reading package lists... Done
Building dependency tree... Done
libspa-0.2-bluetooth : Depends: libspa-0.2-modules (= 0.3.48-1ubuntu1) but 0.3.48-1ubuntu2 is to be installed
pipewire-audio-client-libraries : Depends: pipewire (= 0.3.48-1ubuntu1) but 0.3.48-1ubuntu2 is to be installed
Depends: libpipewire-0.3-0 (= 0.3.48-1ubuntu1) but 0.3.48-1ubuntu2 is to be installed
Running apt list -a showed the following:
pipewire/now 0.3.48-1ubuntu2 amd64 [installed,local]
pipewire/jammy 0.3.48-1ubuntu1 amd64
pipewire/jammy 0.3.48-1ubuntu1 i386
sudo apt install pipewire/jammy and installing pipewire's needed packages and configurations seemed to work except it took out my GUI on reboot. I ultimately had to use timeshift to restore to a previous environment. Any ideas as to why this happened?
