I’m trying to go back to Linux from windows after some viruses. I was able to download and use the live cd of Ubuntu with no problems (a few messages popped up, but I got no errors once up and running). I could also get through the installation with no problems. But when I try to use Ubuntu, I get “error: out of memory” and the errors listed below.
I get the similar errors when trying another distribution (KDE Neon) - in fact, this one didn’t even make it to the install screen.
I’ve tried with secure boot enabled and disabled, and tried multiple installations with different combinations related to secure boot that comes up during the install process.
Any idea what might be going on? I really need a working computer and I’d rather not go back to windows. I don’t need windows, so any way to get a working Linux system is fine for me. I can temporarily work from the live CE, but that’s not a long term solution.
Thank you so much.
Error log (copied from iPhone text reading function, so there may be a few errors):
RE_NOT_FOUND (28218738/psargs-338
1.4442861 ACPI Error:
Aborting method \_SB.PRIB._CPC due to previous error
(RE.NOT _FOUND) (28218738/psparse-529)
1.4443273 ACP! BIOS Érror (bug): Could not resolve sumbol I\_SB.PR88._CPC).
RE.NOT_FOUND (28218738/psargs-338)
1.4443371 RCPI Error: Rborting method \_SB.PR11. _CPC due to previous error
444385] ACPI BIOS
Error (bug): Could not resolve symbol [\_5B.PR88._CPC1,
RE.NOT_FOUND (28218736/psargs-338)
1.4443951 RCPI Error: Aborting method I_SB.PR12. _CPC due to previous error
(RE._NOT_FOUND) (28218738/psparse-529)
1.444438] ACPI BIOS En ror (bug): Could not resolve sumbol d\SB.PROB._CPCI.
RE._HOT_FOUND
(28218738/psargs-330)
1.4444483 ACPI Error:
Aborting nethod I_SB.PRI3. _CPC due to previous error
(RE._NOT _FOUND) (28218738/psparse-529
1.444498] ACPI BIOS Error (bug): Could not resolve suabol I\SB.PRBB._CPC).
RE._NOT_FOUND (28218738/psargs-330)
1.4445881 RCPI Error: Aborting wethod I_SB.PR14._CPC due to previous error
(RE. NOT _ FOUND) (28218738/psparse-529)
1.4445423 RCPI BIOS Error (bug): Could not resolve symbol I\_SB.PRBB._CPC), RE._NOT_FOUND (28218738/psargs-338)
1.4445523 ACPI Error: Aborting method I_SB.PR15._CPC due to previous error
1.5549681 Kernel panic - not suncing: VFS: Unable to mount root fs on unknown-block(8.8)
1.5551483 CPU: 2 PID: 1 Comm: sapper/8 Not tainted 5.15.8-43-generic #46-Ubuntu
1.5553443 Harduare name: GIGABYTE 8/8, BIOS FB85 87/81/2819
1.5554801 Call Trace:
1.5555413
(TRSK>
1.5555961
show_stack+8x52/8x58
1.5556821
1.5557761
dump_stack_1v1+8x4a/8x5f dump_stack+8x18/8x12
1.555868] panic+8x149/8x321
1.555948)
mount_block_root+8x144/8x1d9
1.5568421
mount_root+8x18c/8x118
1.5561383
prepare_nanespace+8x13f/8x1Bd
5562321
kernel-init_freeable+8x18c/8x1b1
5563491
? rest_init+8x188/8x108
5564341
kernel_init+8x1b/8x158
1.5565141
rest_init+8x188/8x188
5566811
ret_fron_fork+8x1f/8x30
5566861
(/TASK>
1.5560151 Kernel Offset: 8/3ae@8888 from Bxffffffff81888880 (relocation range: Bxffffffff88000000-8xffffffffbffrfffr
Artur Meinild
  • 31,035
