-2
My objective is to install Grub 2 on an initially blank drive and then add the boot partition for UEFI so that the UEFI .img can be added and everything can boot as a standalone.
There are instructions at:
MemTest86 Grub Install with Ubuntu Linux
However, these end up with the UEFI boot option as as a sideline GRUB install from the other boot options and not as a standalone.
There is some information about how to install the UEFI .img (like Memtest86+) on top of a fresh install of Ubuntu. Rather I would like to use the root terminal to just add GRUB and configure it from Ubuntu so it is ready to work from a standalone disk with the one UEFI partition and the GRUB boot area:
Wiki Community GRUB installing
The above link is very hard for me to understand. I am looking for simpler instructions or suggestions. Thank you for your suggestions or recommended specific steps.
Update: I made sure that the GRUB version was updated to the latest:
/mnt/boot/memtest86# grub-install --version
grub-install (GRUB) 2.04-1ubuntu26.15
The grub-install proceeded to install GRUB in the boot sector with the force option, and of course specifying not the UBUNTU boot disk, but rather a different SATA disk that I would transfer to the new computer to boot. I am able to boot to the "Grub>" prompt now to manually issue the commands. However, the last command, the chain loader is not working.
On a different computer, everything works fine. But I want to return the USB stick that I purchased to get a refund instead of installing memtest86 V10 there as PassMark, the software developer, supports.
I also found a similar question at this site memtest efi grub installation; however that question dead-ended without a real answer.
Update 2:
I found some other reference(s) that might be helpful:
boot-able setup for BIOS and UEFI
SOLVED: Grub 2 gives Error: Invalid Signature
How to get a UUID from a device from the GRUB2 prompt
I still have not been able to get the chain loader to work, even with the force option, even with boot after. With the force option there is no output except another "grub>" prompt. If I remember correctly, boot just goes to a blank screen.
External drives boot from /EFI/Boot/bootx64.efi. Internal drives may have that entry as fallback or drive boot entry. Ubuntu normally boots from /EFI/ubuntu/shimx64.efi.
You need to create a decent sized ESP - efi system partition on your drive. I do not know how large memtest is.
From my Ubuntu install, so I have grub and a flash drive's ESP labeled focal, mounted at /media/fred, I installed grub. The standalong parameter installs grub to /EFI/Boot. You still have to manually create a grub.cfg in /EFI/ubuntu or /EFI/Boot. Not sure what I did back then. I think I used a typical configfile UEFI entry to load another grub.cfg in another folder similar to how UEFI configfile loads full grub.cfg from install's / partition.
sudo grub-install --target=x86_64-efi --boot-directory=/media/fred/FOCAL/EFI/BOOT --efi-directory=/media/fred/FOCAL --removable
My Kubuntu dolphin does not auto mount ESP partitions, so I have to manually mount to see or edit them.
As per your link on memtest. Then you need to extract your memtest file. Copy to /EFI/memtest/bootx64.efi and create boot stanza. If this drive only for memtest, you can probablyh make the one grub.cfg the example they show for 40_custom
example UEFI configfile:
How make external usb disk bootable for bios and uefi
If you have any live installer ISO, you can mount it and look at folders & grub.cfg it uses for directly booting a flash drive. You configuration needs to be similar.
oldfred
  • 12,583
I was trying the GRUB load previously because the main instructions for creating a USB boot disk for Linux or Mac were not working for me. Also, the GRUB boot instructions did not work. However, now with a newer version of Memtest86 Version 10.1.0009 the Linux USB boot instructions work again, solving the boot problem that was the road-block even with the GRUB boot attempt previously.
Update: I copied the UBUNTU .iso file with dd to an SSD and booted from it in order to install the UEFI version of Ubuntu on the second SSD drive. I was able to UEFI boot it manually using the instructions with a manual GRUB boot from the live UBUNTU SSD:
GRUB boot loader instructions
One thing important to note is that I added the module chain with "insmod chain" and after the "chainloader" step, I had to add the line "boot". I was able to boot to the UEFI Ubuntu Linux in the second drive fine! I copied the necessary files also from the updated memtest86-10.01.009 source .img from the .iso file (easy to do with Ubuntu Disks). I created the recommended directory and then I could manually boot from there also.
So now I can boot from just GRUB. But it is quite a kludge right now because Ubuntu is not putting in GRUB correctly on the disk that it installs the UEFI version of the OS on. There is only one entry for that BOOT disk and it is not working as a boot volume using this second disk's GRUB. Only the Ubuntu live manual GRUB works at this time.
Older comments:
I needed to use a boot disk because the MemTest Free Version 10 from PassMark was not booting. The trouble was that a newer workaround was needed from PassMark. This issue is documented here:
Memtest86 hangs on Boot from USB - Macbook 2014 article from PassMark
The reference image is at this link on that site:
memtest86-usb-10.1.0009.zip file download link
I downloaded the link file and then in the Downloads directory I created a sub-directory named "memtest86-usb-10.1.0009". I copied the zip file into that directory and then used unzip like this:
unzip memtest86-usb-10.1.0009
I then copied the .iso image using dd following this link from the question, being careful to use an actual usb drive instead of an SSD. It may work also from an SSD image also but I have not tried that yet. I used the MemTest86 boot loader instead of GRUB because it is simpler to install:
Creating a MemTest86 bootable USB Flash drive in Linux/Mac
I just boot the Intel computer in BIOS mode and choose the first UEFI entry. The computer is configured in the BIOS for a UEFI boot since version 10, the latest MemTest version, requires that to boot properly according to their web-site.
I am currently testing 32 GB of Memory that had been previously tested with an older version, and all is fine as to be expected.
P.S. I also tested the dd from the .iso file to the SSD /dev/sda and then I moved that SSD drive to another computer and I chose to boot from it from the BIOS selection menu. Everything was fine there also. The computer boots fine and MemTest 10.1 FREE works fine. A next step would be the UEFI installation of Ubuntu. For some reason, my computers lack the UEFI option. I am still trying to figure out how to install Ubuntu on a fresh disk -- with a UEFI boot option.
I did find a reference:
Installation/UEFI-and-BIOS/stable-alternative
But the reference is overly-complicated for me as as-of-yet. Is there a simpler approach that works well?
