I have recently installed Ubuntu 22.04 but the motherboard integrated wireless controller is listed as unclaimed
*-network UNCLAIMED
description: Network controller
product: MEDIATEK Corp.
vendor: MEDIATEK Corp.
physical id: 0
bus info: pci@0000:0d:00.0
version: 00
width: 64 bits
clock: 33MHz
capabilities: pciexpress msi pm cap_list
configuration: latency=0
resources: iomemory:f80-f7f memory:f802100000-f8021fffff memory:fc800000-fc807fff
lspci lists it as
0d:00.0 Network controller: MEDIATEK Corp. Device 0616
And running modinfo mt7921e | grep alias seems to indicate that the MediaTek driver have Device 0616 covered:
alias: pci:v000014C3d00000616sv*sd*bc*sc*i*
alias: pci:v000014C3d00000608sv*sd*bc*sc*i*
alias: pci:v000014C3d00007922sv*sd*bc*sc*i*
alias: pci:v000014C3d00007961sv*sd*bc*sc*i*
dmesg however does list this tidbit:
[ 8.742395] mt7921e 0000:0d:00.0: Message 2000008a (seq 2) timeout
[ 8.742477] mt7921e: probe of 0000:0d:00.0 failed with error -110
So is this an outdated kernel version problem, as some of the other similar cases are? Or is this a hardware problem? It literally worked two minutes ago on a temporary Windows installation (that I have since deleted) so I doubt it's bad hardware.
