I'm trying to install zabbix on my ubuntu 22.04 server.
I installed the zabbix 6.1 repository on my system.
when I try to install zabbix server with mysql support it returns the following:
$ sudo apt install zabbix-server-mysql zabbix-sql-scripts
Reading package lists... Done7
Building dependency tree... Done
zabbix-server-mysql : Depends: libldap-2.4-2 (>= 2.4.7) but it is not installable
Depends: libsnmp35 (>= 5.8+dfsg) but it is not installable
Depends: libssl1.1 (>= 1.1.1) but it is not installable
