---UPDATE
Unfortunately, there was not much to be done with this issue. There is no 'easy fix'. I ended up reinstalling ubuntu. A bit radical, but it worked.
---END UPDATE
I messed up my packages in ubuntu 22.04 when trying to install ffmpeg5 to use alvr, following this guide - https://launchpad.net/~savoury1/+archive/ubuntu/ffmpeg5. One of the steps is dist-upgrade, which happened to delete ubuntu-desktop (I didn't know how risky it was).
Once I fixed having no desktop, most things are working, except steam (missing i386 packages). When trying to install missing i386 packages, I realized that I can't upgrade without errors anymore. I'm beyond my understanding of what went wrong, and I'm afraid of screwing something else up in the process. Below are the outputs of apt-upgrade, me trying to remove one of the packages, and running aptitude safe-upgrade :
apt upgrade output:
$sudo apt upgrade
Reading package lists... Done
Building dependency tree... Done
Calculating upgrade... Done
The following packages have been kept back:
  gcc-12-base:i386 libatomic1:i386 libcurl4:i386 libdbus-1-3:i386 libexpat1:i386 libgcc-s1:i386 libjbig0:i386 libobjc-11-dev libobjc4 libpcre2-8-0:i386
  libpixman-1-0:i386 libpulse0:i386 libsqlite3-0:i386 libssl3:i386 libstdc++6:i386 libsystemd0:i386 libtiff5:i386 libudev1:i386 libwayland-client0:i386
  libwayland-cursor0:i386 libwayland-egl1:i386 libwayland-server0:i386 zlib1g:i386
0 upgraded, 0 newly installed, 0 to remove and 23 not upgraded.
Trying to remove one of the held-back packages
$sudo apt remove gcc-12-base:i386
The following packages have unmet dependencies: libcrypt1:i386 : Depends: libc6:i386 (>= 2.25) but it is not going to be installed E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
Trying to solve via aptitude, which recommends full-resolver, which gives a very complicated result (pasted below).
$sudo aptitude safe-upgrade
Resolving dependencies...
Unable to resolve dependencies for the upgrade: no solution found.
Unable to safely resolve dependencies, try running with --full-resolver.
Complete output, which is a bit scary (I see it will remove an nvidia package, which always is a pain) https://pastebin.com/vJkMdE7C
Drew75
  • 133
