I would like to convert a text file into CSV format.
Here is an excerpt from the file:
{"Outdated":false,"Watt":233,"Timestamp":1669647142,"A_Plus":6523.896,"A_Plus_HT":4494.82,"A_Plus_NT":2029.076,"A_Minus":8841.63}
{"Outdated":false,"Watt":235,"Timestamp":1669647152,"A_Plus":6523.896,"A_Plus_HT":4494.82,"A_Plus_NT":2029.076,"A_Minus":8841.63}
{"Outdated":false,"Watt":235,"Timestamp":1669647596,"A_Plus":6523.896,"A_Plus_HT":4494.82,"A_Plus_NT":2029.076,"A_Minus":8841.63}
{"Outdated":false,"Watt":233,"Timestamp":1669651191,"A_Plus":6524.496,"A_Plus_HT":4495.42,"A_Plus_NT":2029.076,"A_Minus":8841.63}
{"Outdated":false,"Watt":276,"Timestamp":1669654797,"A_Plus":6524.816,"A_Plus_HT":4495.74,"A_Plus_NT":2029.076,"A_Minus":8841.63}
{"Outdated":false,"Watt":437,"Timestamp":1669658393,"A_Plus":6525.901,"A_Plus_HT":4496.825,"A_Plus_NT":2029.076,"A_Minus":8841.63}
{"Outdated":false,"Watt":362,"Timestamp":1669661992,"A_Plus":6526.732,"A_Plus_HT":4497.656,"A_Plus_NT":2029.076,"A_Minus":8841.63}
{"Outdated":false,"Watt":471,"Timestamp":1669665603,"A_Plus":6527.062,"A_Plus_HT":4497.986,"A_Plus_NT":2029.076,"A_Minus":8841.63}
The structure resembles a JSON file, but unfortunately the structure does not quite match. I have already used this tool (https://github.com/alingse/jsoncsv), but unfortunately I get error messages because of the wrong structure.
How can I turn it into a CSV file?
Thanks for your help!
muru
  • 207,228
Each row of your input is a valid JSON object - so if you don't care about CSV headers, you could simply deconstruct them back into arrays and pass them through the @csv filter:
$ jq -r '[.[]] | @csv' file
false,233,1669647142,6523.896,4494.82,2029.076,8841.63
false,235,1669647152,6523.896,4494.82,2029.076,8841.63
false,235,1669647596,6523.896,4494.82,2029.076,8841.63
false,233,1669651191,6524.496,4495.42,2029.076,8841.63
false,276,1669654797,6524.816,4495.74,2029.076,8841.63
false,437,1669658393,6525.901,4496.825,2029.076,8841.63
false,362,1669661992,6526.732,4497.656,2029.076,8841.63
false,471,1669665603,6527.062,4497.986,2029.076,8841.63
If you do care about headers, it's more complicated. The best I could come up with is:
  • slurp the whole file into an indexed array of rows
  • perform a reduction of the array of rows, initializing it with the keys extracted from the 0th element
You now have an array-of-arrays, with a header array at the top, that may be mapped back to an array of CSV (and finally to individual CSV rows):
$ jq -r --slurp 'to_entries |
    reduce . as $row ([.[0] | .value | keys_unsorted]; . + [$row[] | .value | to_entries | map(.value)]) |
    map(@csv) | .[]
  ' file
"Outdated","Watt","Timestamp","A_Plus","A_Plus_HT","A_Plus_NT","A_Minus"
steeldriver
  • 142,475
This is a very used data format, Json lines
You can use Miller 6 and run
mlrgo --ijsonl --ocsv cat input.jsonl
to get
Outdated,Watt,Timestamp,A_Plus,A_Plus_HT,A_Plus_NT,A_Minus
In the useful comment below, there is a note about the way to do it in Miller 5:
mlr --ijson --ocsv cat input >output
aborruso
  • 814
For me it seems easier and safer to first convert to proper json, then use a parser (e.g. jq or jsoncsv that you have tried) instead of writing your own parser.
Convert to json by simply adding [ in then first row and append ] after the last row and a comma to every except the last row.
sed '1s/^/[/;$!s/$/,/;$a]' file
Then convert to csv using jq
jq -r '(.[0] | keys_unsorted) as $keys | $keys, map([.[ $keys[] ]])[] | @csv'
And put it together:
$ sed '1s/^/[/;$!s/$/,/;$a]' file | jq -r '(.[0] | keys_unsorted) as $keys | $keys, map([.[ $keys[] ]])[] | @csv'
pLumo
  • 27,991
The type of data you provide in your example is called Newline delimited JSON(AKA NDJSON) ... There are tools that support it natively like in2csv which is provided by the csvkit package ... so install it first like so:
sudo apt install csvkit
Then, specify the format with the option -f ndjson and simply use it on your file like so:
in2csv -f ndjson file
That should result in:
False,233,1669647142,6523.896,4494.82,2029.076,8841.63
False,235,1669647152,6523.896,4494.82,2029.076,8841.63
False,235,1669647596,6523.896,4494.82,2029.076,8841.63
False,233,1669651191,6524.496,4495.42,2029.076,8841.63
False,276,1669654797,6524.816,4495.74,2029.076,8841.63
False,437,1669658393,6525.901,4496.825,2029.076,8841.63
False,362,1669661992,6526.732,4497.656,2029.076,8841.63
False,471,1669665603,6527.062,4497.986,2029.076,8841.63
Raffa
  • 34,963
