10
I used a friend's Android (2.3) phone that allows USB tethering, subheading: "share phone's mobile network with PC."
Android lets me set 2 tethering settings, under "USB tethering type":
  • Windows
  • Mac OS X
Naturally, Linux isn't officially supported, but I suspect someone has run into this before. What do I need to on my Ubuntu 12.04 setup to get it to recognize either of these connection types for USB tethering?
Mittenchops
  • 1,640
My last phone ran Android 2.3 and i had no problems with USB tethering. I could set the USB connection to default to tethering and all i had to do was plug it in to my Linux laptop and it was online. So it's not Android 2.3 - but it may be your carrier. I believe Optus may not allow tethering on prepaid. I'm with Telstra and they do.
Yes..I have also experienced same problem. This is due to carrier. I am from India. There are two carriers namely IDEA and AirTel. I was able to connect with IDEA on 3G but for AIRTEL no luck but when I switched Airtel network to 2G, I was able to connect sadly speed was low. May be you can change the network type
