Where am I going wrong in this Bash?
declare current_state=`pacmd list-sources | sed -n 19p`
declare my_target='used by: 0'
echo $current_state = $my_target
if [ '$current_state' = '$my_target' ] ; then
echo true
pacmd set-default-sink "alsa_output.pci-0000_0c_00.4.analog-stereo"
echo true
else
echo false
pacmd set-default-sink "alsa_output.pci-0000_0a_00.1.hdmi-stereo-extra2"
echo false
fi
It is always outputting the else (false) option to terminal:
used by: 0 = used by: 0
false
false
I have tried if [[ '$current_state' = '$my_target' ]] , if [[ '$current_state' == '$my_target' ]], if [ '$current_state' == '$my_target' ], if [ '$current_state' == 'used by 0:' ], if [ '$current_state' = 'used by 0:' ], etc. It's always coming back as false.
For context, I was trying to use scripts from How to switch sound output with key shortcut but none of those work because my output indeces are 2, 3, and 30. Because that makes sense. Anyway, I found by running the pacmd list-sources while varying the manually selected outputs out of Sound Settings differences in a few lines. (Line 6 was what I initially tried, and it would report the status of one of index 2 (the first one, yes, the first) as state: IDLE, state: RUNNING, or state: SUSPENDED.) I managed to make the bash script work once to change from my headphones to my monitor, and then no more. So I tried changing where I look to this line 19 output which tells me if it's in use (I think) with either used by: 1 when active or used by: 0 when inactive to just toggle. But nope, no luck.
So then I get into the basic troubleshooting to make sure my if/else is evaluating correctly, and it's not. I don't know what I'm supposed to do here. Did I screw something up with declare?? I don't know.
