While trying to update my Cuda driver and toolkit using the following link, i am getting the below error
$ sudo apt-get install cuda
Reading package lists... Done
Building dependency tree... Done
cuda-drivers-520 : Depends: nvidia-settings (>= 520.61.05) but it is not installable
nsight-systems-2022.4.2 : Depends: libtinfo5 but it is not installable
Also, i tried to install cuda driver using the .run file from the same link, it did work but it seems the cuda toolkit are not installed. I use
$ nvcc --version
Command 'nvcc' not found, but can be installed with:
sudo apt install nvidia-cuda-toolkit
Will appreacite if someone can help me !
