Same issue here, the thing is TLSv1 standar for encryption was found insecure, so OpenSSL had to eliminate it from the software. I'm afraid TLSv1 is gone for good.
So after three hours of trying to reconfigure OpenSSL 3.0.2 un Ubuntu 22.04, I took a deep breath and I thought "you must think out of the box", so I came with an alternative solution.
MySoftware in TLSWhatEverVersion > HTTPSApache2Proxy > WebservicesServerInTLSv1
So the idea is to use Apache2 to translate from TLSv1 to whatever you need and backwards.
The solution is to use "Apache2" as a reverse proxy to translate from TLSv1 to what ever I ask him through https, and it works great. It took me about 1 hour to configur "Apache2" trying different configurations, and activating the different modules needed to do the task.
First you hae to install "Apache2":
Second you have to test it:
http://<WhatEverIp> in your web browser.
Third, enable SSL module in "Apache2":
Fourth, enable Proxy module on "Apache2":
And at last you hace to add the virtual host to your sites-enabled config file (/etc/apache2/sites-enabled/000-default.conf):
- Add at the end of the file:
<VirtualHost *:port>
ProxyPass / https://<TLSv1 IP of origin>:<port>/
ProxyPassReverse / https://<TLSv1 IP of origin>:<port>/
SSLEngine on
SSLProxyEngine on
SSLProxyEngine on
SSLProxyVerify none
SSLProxyCheckPeerCN off
SSLProxyCheckPeerName off
SSLProxyCheckPeerExpire off
SSLCipherSuite AES256+EECDH:AES256+EDH
SSLProtocol All -SSLv2 -SSLv3 -TLSv1 -TLSv1.1
SSLCertificateFile /etc/apache2/certs/<selfSignedCertName>.crt
SSLCertificateKeyFile /etc/apache2/certs/<selfSignedCertName>.key
</VirtualHost>
Aditional: to generate self signed certificates:
mkdir /etc/apache2/certs
cd /etc/apache2/certs
openssl genrsa -out mysite.com.key 1024
openssl req -new -key mysite.com.key -out mysite.com.csr
openssl x509 -req -days 100000 -in mysite.com.csr -signkey mysite.com.key -out mysite.com.crt
If you have any questions, please ask them, because my distorted brain some times works in mysterious ways.
Kind regards from Chile.
Links for recreating the solution:
