Deja Dup (DD) has worked w/o problem for 2+ years under Ubuntu Mate 18.04 - then I upgraded to 20.04 and DD no longer succeeds.
DD halts when "back up now", with window "Storage location not available. Waiting for a network connection..."
DD is configured to access a local network NAS hard disk (ethernet) using smb:// protocol
When file manager Caja mounts a NAS share, it does so using smb://, and DD is configured to access that particular smb:// share.
The DD Developer/Maintainer suggests something is not set up correctly with my networking, though I can navigate my LAN and the Internet w/o problem. I've sent him this terminal window info:
(from 'sysinfo') Running Ubuntu Linux, the Ubuntu 20.04 (focal) release. GNOME: 3.36.8 (Ubuntu) Kernel version: 5.4.0-132-generic (#148-Ubuntu SMP Mon Oct 17 16:02:06 UTC 2022) GCC: 9 (x86_64-linux-gnu)
gandsnut@tinyhp:~$ nm-online
Connecting............... 0s [offline]
gandsnut@tinyhp:~$ ps -afe | grep -i "network"
systemd+ 1108 1 0 Nov17 ? 00:00:13 /lib/systemd/systemd-networkd
root 1233 1 0 Nov17 ? 00:00:06 /usr/sbin/NetworkManager --no-daemon
root 1254 1 0 Nov17 ? 00:00:00 /usr/bin/python3 /usr/bin/networkd-dispatcher --run-startup-triggers
gandsnut 3638 2161 0 Nov17 ? 00:00:00 /usr/libexec/gvfsd-network --spawner :1.3 /org/gtk/gvfs/exec_spaw/1
I don't know what to fix to make DD function again. Suggestions?
================== (added) The output from the suggested command repeats 8 times...
gandsnut@tinyhp:~$ systemctl status NetworkManager
● NetworkManager.service - Network Manager
Loaded: loaded (/lib/systemd/system/NetworkManager.service; enabled; vendor preset: enabled)
Active: active (running) since Thu 2022-11-17 04:00:49 CST; 2 days ago
Docs: man:NetworkManager(8)
Main PID: 1233 (NetworkManager)
Tasks: 3 (limit: 37743)
Memory: 12.2M
CGroup: /system.slice/NetworkManager.service
└─1233 /usr/sbin/NetworkManager --no-daemon
Nov 17 04:00:50 tinyhp NetworkManager[1233]: <info> [1668679250.7002] device (lo): carrier: link connected
Nov 17 04:00:50 tinyhp NetworkManager[1233]: <info> [1668679250.7013] manager: (lo): new Generic device (/org/freedesktop/NetworkManager/Devices>
Nov 17 04:00:50 tinyhp NetworkManager[1233]: <info> [1668679250.7049] manager: (enp2s0): new Ethernet device (/org/freedesktop/NetworkManager/De>
Nov 17 04:00:50 tinyhp NetworkManager[1233]: <info> [1668679250.7255] manager: (wlp1s0): new 802.11 Wi-Fi device (/org/freedesktop/NetworkManage>
Nov 17 04:00:50 tinyhp NetworkManager[1233]: <info> [1668679250.7407] device (wlp1s0): state change: unmanaged -> unavailable (reason 'managed',>
Nov 17 04:00:50 tinyhp NetworkManager[1233]: <info> [1668679250.9059] modem-manager: ModemManager available
Nov 17 04:00:50 tinyhp NetworkManager[1233]: <info> [1668679250.9096] manager: startup complete
Nov 17 04:00:50 tinyhp NetworkManager[1233]: <info> [1668679250.9295] supplicant: wpa_supplicant running
Nov 17 04:01:01 tinyhp NetworkManager[1233]: <info> [1668679261.2166] device (enp2s0): carrier: link connected
Nov 17 04:01:32 tinyhp NetworkManager[1233]: <info> [1668679292.2178] agent-manager: agent[f83f5a498d6fe2d9,:1.110/org.freedesktop.nm-applet/100>
lines 1-20/20 (END)...skipping...
