I upgraded our webserver to Ubuntu v22 and am now unable to login via Putty after restart, it says "Server Refused our Key," and a prompt "Disconnected: No supported authentication methods available (Server sent: publickey)." It was working fine before this.
I can still login using the same private key using FileZilla / SFTP.
After the restart the server did not start my webserver and the website is down, so any help you can provide I will be grateful.
Waqas Tariq
  • 1,023
  • 13
I upgrade my digitalocean droplet from ubuntu 18.04 to 20.04 to 22.04. There is no problem on my putty ssh at 20.04. but "refused our key" when I upgraded to 22.04.
I fix the problem after update my putty from 0.74 to 0.78.
https://www.systemtek.co.uk/2019/03/how-to-update-putty/
hope this could help.
I created an ED25519 key, and then used FileZilla to access /home/ubuntu/.ssh to replace the key and change file permission to 600. This gave me access to the server
Waqas Tariq
  • 1,023
  • 13
I ran into the same issues with Ubuntu Mate 20.04 to 22.04 upgrade. Every time I tried to access the server through SSH I keep getting "key is refused". I could still access the server with WinSCP.
I was able to fix the issue by just upgrading Kitty (a fork of Putty).
So for anyone else that runs into this issue in the future, first try upgrading your SSH Client.
TechLoom
  • 101
