24
When I run apt update and apt upgrade on my system, I get this message:
 News about significant security updates, features and services will
 appear here to raise awareness and perhaps tease /r/Linux ;)
 Use 'pro config set apt_news=false' to hide this and future APT news.
What is meant by 'APT News' ?
Thanks.
Artur Meinild
  • 31,035
Sad3ng
  • 443
This is another example of Canonical adding their "advertising stuff" to terminal commands.
I believe that by 'APT News', they are simply referring to their own infomercials in the apt output (so it's a meta-reference so to speak).
Running this command will disable that output: (sudo might be needed)
sudo pro config set apt_news=false
For manual configuration, this command writes to the file /etc/ubuntu-advantage/uaclient.conf. This is an example config file:
# Ubuntu Pro client config file.
# If you modify this file, run "pro refresh config" to ensure changes are
# picked up by Ubuntu Pro client.
contract_url: https://contracts.canonical.com daemon_log_file: /var/log/ubuntu-advantage-daemon.log data_dir: /var/lib/ubuntu-advantage log_file: /var/log/ubuntu-advantage.log log_level: debug security_url: https://ubuntu.com/security timer_log_file: /var/log/ubuntu-advantage-timer.log ua_config: apt_http_proxy: null apt_https_proxy: null apt_news: false global_apt_http_proxy: null global_apt_https_proxy: null http_proxy: null https_proxy: null metering_timer: 14400 ua_apt_http_proxy: null ua_apt_https_proxy: null update_messaging_timer: 21600 update_status_timer: 43200
So if you edit this file, be sure to run this command afterwards:
sudo pro refresh config
Artur Meinild
  • 31,035
