TL;DR How do a verify that a deb file is complete and without error?
I have an incomplete download of a deb package that will error out on install. Before trying to install it, I would like to check if it's valid. As noted in how-to-inspect-and-validate-a-deb-package-before-installation, I can use dpkg-deb --info <deb file> however this gives all the info but does not show any errors on my file.
In my particular case, I have the following file
curl -r 0-28208916 https://download.docker.com/linux/ubuntu/dists/jammy/pool/stable/amd64/docker-ce-cli_20.10.21~3-0~ubuntu-jammy_amd64.deb
The following shows the info of the deb but does not report an incomplete file
dpkg-deb --info docker-ce-cli_20.10.21~3-0~ubuntu-jammy_amd64.deb
Output from dpkg-deb command,
new Debian package, version 2.0.
size 28208917 bytes: control archive=5436 bytes.
1059 bytes, 24 lines control
14836 bytes, 195 lines md5sums
Package: docker-ce-cli
Source: docker-ce
Version: 5:20.10.21~3-0~ubuntu-jammy
Architecture: amd64
Maintainer: Docker <support@docker.com>
Installed-Size: 145640
Depends: libc6 (>= 2.34)
Recommends: docker-scan-plugin
Conflicts: docker (<< 1.5~), docker-engine, docker-engine-cs, docker.io, lxc-docker, lxc-docker-virtual-package
Breaks: docker-ce (<< 5:0)
Replaces: docker-ce (<< 5:0)
Section: admin
Priority: optional
Homepage: https://www.docker.com
Description: Docker CLI: the open-source application container engine
Docker is a product for you to build, ship and run any application as a
lightweight container
Docker containers are both hardware-agnostic and platform-agnostic. This means
they can run anywhere, from your laptop to the largest cloud compute instance and
everything in between - and they don't require you to use a particular
language, framework or packaging system. That makes them great building blocks
for deploying and scaling web apps, databases, and backend services without
depending on a particular stack or provider.
