I was trying to install latex on Ubuntu 22.04 by installing miktex. After following the steps outlined on the website, I ran into the following error message:
The following packages have unmet dependencies: miktex : Depends: libboost-locale1.65.1 but it is not installable Depends: libhunspell-1.6-0 but it is not installable Depends: libicu60 (>= 60.1-1~) but it is not installable Depends: liblog4cxx10v5 (>= 0.10.0) but it is not installable Depends: libssl1.1 (>= 1.1.0) but it is not installable E: Unable to correct problems, you have held broken packages.
I googled around, and tried to install openssl 1.1.1 manually. However, the error messages seem to persist. Any suggestions as to what I should undertake to fix this?
dpkg --get-selections | grep hold
yields no output
and
sudo aptitude install miktex
yields
The following NEW packages will be installed:
  libqt5concurrent5{a} libqt5qml5{a} libqt5script5{a} libqt5scripttools5{a} libqt5xml5{a}
  liburiparser1{a} libzzip-0-13{a} miktex{b}
0 packages upgraded, 8 newly installed, 0 to remove and 0 not upgraded.
Need to get 38.0 MB of archives. After unpacking 121 MB will be used.
 miktex : Depends: libboost-locale1.65.1 which is a virtual package and is not provided by any available package
      Depends: libhunspell-1.6-0 which is a virtual package and is not provided by any available package
      Depends: libicu60 (>= 60.1-1~) which is a virtual package and is not provided by any available package
      Depends: liblog4cxx10v5 (>= 0.10.0) which is a virtual package and is not provided by any available package
      Depends: libssl1.1 (>= 1.1.0) which is a virtual package and is not provided by any available package
Nmath
  • 12,664
James
  • 111
