As you've mentioned that you've already looked at how to create a desktop launcher for your AppImage, I will skip that part.
You're looking to edit the .desktop launcher and change what mime types are associated with it.
FWIW, this is not specifically for AppImages; this is how freedesktop desktop launchers work
I don't know what program you're referring to, but I'll use the following launcher as an example.
The launcher below is for a text editor called Nota. We're interested in the line MimeType=; as you can see, it reads MimeType=text/plain; which means that Nota is associated with any text file.
[Desktop Action FirejailProfile]
Exec=firejail --env=DESKTOPINTEGRATION=appimaged --private --appimage /Applications/nota
Name=Run without sandbox profile
TryExec=firejail
[Desktop Entry]
Categories=Qt;KDE;Utility;TextEditor;
Comment[es_MX]=Text editor
Comment=Text editor
Exec=/home/uri/Applications/nota-v2.2.0-stable-amd64.AppImage
GenericName[es_MX]=Text Editor
GenericName=Text Editor
Icon=nota
Keywords=text;editor;
Name[es_MX]=Nota
Name=Nota
Path=
StartupNotify=true
Terminal=false
TerminalOptions=
TryExec=/Applications/nota
Type=Application
X-DBUS-ServiceName=
X-DBUS-StartupType=
X-KDE-SubstituteUID=false
X-KDE-Username=
You can do the following to know what to put in that line for the desktop launcher you've created.
file -b --mime-type file.stl
This command will tell you what the mime type is. For example, the output could be application/sla for your .stl files.
So, the line in your desktop launcher would read MimeType=application/sla; so the desktop launcher would be registered to launch whatever is in Exec= and open that mime type.
Alternatively, you probably want to extract the upstream desktop launcher inside the AppImage and edit it accordingly, as I described here.
Next, edit ~/.config/mimeapps.list, and append:
application/sla=YourApp.desktop;
