-3
I have searched for this question in the forum but something is not clear to me. They say that if I have Single-Boot I only have to install Windows on the partition where Ubuntu is installed and the installer will do the rest. Is that correct? If so then my question is: How do I know which partition Ubuntu is installed on? I don't have much knowledge of Ubuntu so please be detailed with the answer so I can understand it. Thanks
we need ntfs format partition to get the windows installed.
As you have mentioned that many suggested you can only make single boot. i.e if you install ubuntu with single boot the total file system will be in ext2,ext3,fat ... but not ntfs, So you can't seperate the partition,
if windows installation need to be done, the file system should be changed,So linux changes will be over written(need to be formatted).
