This is my first post on stackexchange and I am a Linux newbie, so if I misconduct anyhow, let me know.
Every time I try to ssh (or telnet) into anything that isn't localhost I cannot connect due to connection time out. Example of output after running ssh -vvv git@github.com:
OpenSSH_8.9p1 Ubuntu-3, OpenSSL 3.0.2 15 Mar 2022
debug1: Reading configuration data /home/klnsptr/.ssh/config
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: /etc/ssh/ssh_config line 19: include /etc/ssh/ssh_config.d/*.conf matched no files
debug1: /etc/ssh/ssh_config line 21: Applying options for *
debug3: expanded UserKnownHostsFile '~/.ssh/known_hosts' -> '/home/klnsptr/.ssh/known_hosts'
debug3: expanded UserKnownHostsFile '~/.ssh/known_hosts2' -> '/home/klnsptr/.ssh/known_hosts2'
debug2: resolving "github.com" port 22
debug3: resolve_host: lookup github.com:22
debug3: ssh_connect_direct: entering
debug1: Connecting to github.com [140.82.121.3] port 22.
debug3: set_sock_tos: set socket 3 IP_TOS 0x10
debug1: connect to address 140.82.121.3 port 22: Connection timed out
ssh: connect to host github.com port 22: Connection timed out
Another thing is that I can clone github repositories if I do it over https. However, trying to use an ssh address leaves me at a "Cloning into 'x'..." prompt and later timing out.
I don't think the issue is with my ISP since ssh works perfectly fine on my Windows 10 (using PuTTY), and on a Macbook connected to the same network.
Also, my firewall is turned off so I that's not the issue either.
Tried: reinstalling ssh, rebooting the system, restarting the router, deleting ssh_config. No google search resolved the problem.
My setup is: Ubuntu 22.04 on one SSD (C:) and Win 10 on other SSD(D:). Using grub to boot into one or the other. The pc is connected to a stock router I got from the ISP via an Ethernet cable.
How do I fix this?
Thanks
EDIT: -no vpn -firewall off (ufw status: inactive)
EDIT 2: reinstalled ubuntu, the issue persists.
EDIT 3: So I created a VM from the same iso that I installed ubuntu with just to check what happens. Turns out ssh works in the VM. (?????)
EDIT 4: Reinstalled ubuntu again, updated to 22.10 - nothing. Then, I downgraded to 20.04 - the issue is resolved, ssh works just fine now. However, I am still looking for a solution for 22.04 if anyone has any ideas.
