11
I am running Ubuntu Server 12.04. I have a wireless USB card. When I begin the boot process I see:
Waiting for network configuration
It turns out that the network never comes up. But once I get to the command line, if I type: ifup wlan0, then I have network access. My /etc/network/interfaces looks like this:
# The loopback network interface
auto lo
iface lo inet loopback
# The primary network interface
auto wlan0
iface wlan0 inet dhcp
wpa-ssid xxxxxxx
wpa-psk xxxxxxxx
Looking in my network-interface-wlan0.log shows:
Failed to connect to wpa_supplicant - wpa_ctrl_open: Read-only file system
Failed to bring up wlan0.
ifdown: interface wlan0 not configured
I've looked at other askubuntu.com questions similar to this, but they don't seem to apply.
How can I get my system to network wirelessly at boot?
Additional information:
I did some poking around. Basically once I login I need to do a:
ifdown wlan0
because I think that ip thinks that is is up, but in /var/run/network the only thing that is 'up' is ifup.lo. Then I do a
'ifup -a'
and then everything works.
5 Answers5
12
According to your log you 'll need to use wpa_supplicant.
So add something similar to this:
auto wlan0
wpa-conf /etc/wpa_supplicant.conf
Contents of /etc/wpa_supplicant.conf :
network={
        ssid="ADD-YOUR-SSID-HERE"
        proto=RSN
        key_mgmt=WPA-PSK
        pairwise=CCMP TKIP
        group=CCMP TKIP
        psk="ADD-YOUR-WPA-PASSWORD-HERE"
pl1nk
  • 6,667
You can add ifup wlan0 to your /etc/rc.local file. Add the command ifup wlan0 before the exit 0. Also add the command ifdown wlan0 before the ifup wlan0 like so:
ifdown wlan0
ifup wlan0
exit 0
For some reason when Ubuntu starts, it thinks that wlan0 is up. So you have to shut it down and have it back up again.
con-f-use
  • 19,041
Connecting to WPA-PSK and WPA2-PSK (Aka "WPA Personal" and "WPA2 Personal" respectively)
  • Run:
    $ wpa_passphrase myssid my_very_secret_passphrase
Copy the value of "psk=" from the output above.
  • Open /etc/network/interfaces in a text editor :
    $ sudo sensible-editor /etc/network/interfaces
  • Define appropriate stanzas for your wireless interface, along with the SSID and PSK HASH. For example :
    auto wlan0
       wpa-ssid <myssid>
       wpa-psk <ccb290fd4fe6b22935cbae3144..>
  • Finally run:
    $ sudo ifup wlan0
Note: Some answers seems to suggest configuring a separate wpa_supplicant.conf. But it is only required for WPA-EAP, EAP-TLS networks.
The auto stanza does bring up the interface at system startup.
Gayan Weerakutti
  • 3,830
  • 28
  • 39
I also encounter such a problem.
I noticed that someone said, delete the text about primary network interface, with first 2 lines remaining.
It works, but no network is connected.
Then I write the text of primary network interface back into the interfaces file and reboot.
It's surprising to find not only no hints "waiting for network configuration" occur, but I could connect to the internet.
I don't know whether it is useful for any others.
The reason for this is that the filesystem is read-only at boot. At this point only static settings work because udev raises network hotplug signal before the filesystem is ready.
The solution is to change the /etc/init/network-interface.conf file in this line:
"ifup --allow auto ..." to
"ifup --allow=hotplug ...".
You will have to mark you hotplug PCMCI and USB network adapters as "hotplug" in /etc/network/interfaces for them to continue to work, and you should plug them in after boot, not before.
Lucio
  • 19,191
  • 32
  • 112
  • 191
Arunas
