After updating from Ubuntu 20.04 → 22.04 LTS I am unable to boot. Upon boot the following text keeps blinking:
/div/sda5: clean, xxx/xxx files, xxx/xxx blocks
[64.xx] snd_hda_intel 0000:00"03.0: HSW/BDW HD-audio HDMI/DP requires binding with gfx driver
Hardware: Gigabyte BRIX (Intel HD Graphics 5500).
Is anyone familiar with this issue? I am able to login using SSH.
EDIT: I found out what may have caused the issue. Because I use Ubuntu without a monitor I used the information in this post to setup a dummy display. However before the update I reverted these changes (i.e. by removing /etc/X11/xorg.conf) because with the dummy display enabled, regular displays do not work. After re-enabling the dummy display I can now see the Ubuntu again (over TeamViewer). However, still no output on physical displays. Does anybody have an idea how I can properly disable the dummy display so that I can access Ubuntu through a physical monitor again?
