Dual boot machine with Ubuntu 20.04 and Windows 10 on seperate m.2 nvme storage devices. I have an external hard drive (14TB) set up as NTFS. On either operating system I can write to the disc. However, when I open files on the HD in Windows 10, if I generated those files using Ubuntu 20.04, they are often corrupted. For example:
D:\my\path> type myfile.mrc.tlt
The file or directory is corrupted and unreadable.
I have seen this behavior on two external hard drives (one Seagate and another WD). I had assumed the problem was with the Seagate drive. But I have now replicated it with a WD one.
Not sure where to start toubleshooting from here.
When I mount the drive while running journalctl -f I get the following:
Nov 05 17:12:21 axoneme udisksd[894]: Mounted /dev/sdd1 at /media/jared/Elements on behalf of uid 1000
Nov 05 17:12:21 axoneme dbus-daemon[1641]: [session uid=1000 pid=1641] Activating via systemd: service name='org.freedesktop.Tracker1' unit='tracker-store.service' requested by ':1.1' (uid=1000 pid=1637 comm="/usr/libexec/tracker-miner-fs " label="unconfined")
Nov 05 17:12:21 axoneme systemd[1629]: Starting Tracker metadata database store and lookup manager...
Nov 05 17:12:21 axoneme dbus-daemon[1641]: [session uid=1000 pid=1641] Activating service name='org.gnome.Shell.HotplugSniffer' requested by ':1.37' (uid=1000 pid=1860 comm="/usr/bin/gnome-shell " label="unconfined")
Nov 05 17:12:21 axoneme dbus-daemon[1641]: [session uid=1000 pid=1641] Successfully activated service 'org.gnome.Shell.HotplugSniffer'
Nov 05 17:12:21 axoneme dbus-daemon[1088]: [session uid=125 pid=1088] Successfully activated service 'org.freedesktop.Tracker1'
Nov 05 17:12:21 axoneme systemd[1072]: Started Tracker metadata database store and lookup manager.
Nov 05 17:12:21 axoneme dbus-daemon[1641]: [session uid=1000 pid=1641] Successfully activated service 'org.freedesktop.Tracker1'
Nov 05 17:12:21 axoneme systemd[1629]: Started Tracker metadata database store and lookup manager.
Nov 05 17:12:21 axoneme ntfs-3g[5491]: Trying to read non-allocated mft records (10255 > 9984): Illegal seek
Nov 05 17:12:21 axoneme ntfs-3g[5491]: Trying to read non-allocated mft records (10256 > 9984): Illegal seek
Nov 05 17:12:21 axoneme ntfs-3g[5491]: Trying to read non-allocated mft records (10164 > 9984): Illegal seek
Nov 05 17:12:21 axoneme ntfs-3g[5491]: Trying to read non-allocated mft records (10165 > 9984): Illegal seek
Nov 05 17:12:22 axoneme ntfs-3g[5491]: Trying to read non-allocated mft records (10009 > 9984): Illegal seek
Nov 05 17:12:22 axoneme ntfs-3g[5491]: Trying to read non-allocated mft records (10010 > 9984): Illegal seek
Nov 05 17:12:22 axoneme ntfs-3g[5491]: Trying to read non-allocated mft records (10030 > 9984): Illegal seek
Nov 05 17:12:22 axoneme ntfs-3g[5491]: Trying to read non-allocated mft records (10031 > 9984): Illegal seek
Similarly, if I run ls -lth in a directory on the NTFS HD with Ubuntu 20.04, I get the following in the corrupted directorys:
Nov 05 17:16:03 axoneme ntfs-3g[5491]: Trying to read non-allocated mft records (10294 > 9984): Illegal seek
Nov 05 17:16:03 axoneme ntfs-3g[5491]: Trying to read non-allocated mft records (10290 > 9984): Illegal seek
Nov 05 17:16:03 axoneme ntfs-3g[5491]: Trying to read non-allocated mft records (10360 > 9984): Illegal seek
