When I try to boot my machine, this is the output:
Ubuntu 22.04.1 LTS <my_name>-pc tty1
<my_name>-pc login:
The whole screen is black. If I login in then it's like I'm in a huge terminal because I can run command in.
Answering my own question.
To anyone that is having the same problem as me, and is not really technical (like me), here's what solved it for me.
What I was seeing was tty (“teletypewriter”), which is a text-only terminal commonly used as a way to get access to the computer to fix things. I was put into this "environment" because I somehow (after an update) managed to uninstall my desktop.
My advice is:
  1. Log in into tty with your username and password.
  2. Check if you have the ubuntu-desktop package installed. I did this by typing sudo apt remove ubuntu-desktop, which returned something like package not found.
  3. If you find out that the package is missing, run sudo apt install ubuntu-desktop. After the installation, my desktop opened automatically and everything was fine.
Hope this helps somebody!
