I upgraded from 11.10 to 12.04, had no issues that I noticed. Recently tried to install something via software center, but it was throwing errors. Changed to trying to sudo apt-get install instead but again no luck. I've genuinely tried as much as I know to fix this, but I can't so I figured I'd ask here.
I've done sudo apt-get update successfully but sudo apt-get upgrade failed with...
You might want to run ‘apt-get -f install’ to correct these.
The following packages have unmet dependencies.
ia32-libs-multiarch:i386 : Depends: libqtcore4:i386 but it is not installed
libqt4-dbus:i386 : Depends: libqtcore4:i386 (= 4:4.8.1-0ubuntu4.1) but it is not installed
libqt4-declarative:i386 : Depends: libqtcore4:i386 (= 4:4.8.1-0ubuntu4.1) but it is not installed
libqt4-designer:i386 : Depends: libqtcore4:i386 (= 4:4.8.1-0ubuntu4.1) but it is not installed
libqt4-network:i386 : Depends: libqtcore4:i386 (= 4:4.8.1-0ubuntu4.1) but it is not installed
libqt4-opengl:i386 : Depends: libqtcore4:i386 (= 4:4.8.1-0ubuntu4.1) but it is not installed
libqt4-qt3support:i386 : Depends: libqtcore4:i386 (= 4:4.8.1-0ubuntu4.1) but it is not installed
libqt4-script:i386 : Depends: libqtcore4:i386 (= 4:4.8.1-0ubuntu4.1) but it is not installed
libqt4-scripttools:i386 : Depends: libqtcore4:i386 (= 4:4.8.1-0ubuntu4.1) but it is not installed
libqt4-sql:i386 : Depends: libqtcore4:i386 (= 4:4.8.1-0ubuntu4.1) but it is not installed
libqt4-sql-mysql:i386 : Depends: libqtcore4:i386 (= 4:4.8.1-0ubuntu4.1) but it is not installed
libqt4-svg:i386 : Depends: libqtcore4:i386 (= 4:4.8.1-0ubuntu4.1) but it is not installed
libqt4-test:i386 : Depends: libqtcore4:i386 (= 4:4.8.1-0ubuntu4.1) but it is not installed
libqt4-xml:i386 : Depends: libqtcore4:i386 (= 4:4.8.1-0ubuntu4.1) but it is not installed
libqt4-xmlpatterns:i386 : Depends: libqtcore4:i386 (= 4:4.8.1-0ubuntu4.1) but it is not installed
libqtgui4:i386 : Depends: libqtcore4:i386 (= 4:4.8.1-0ubuntu4.1) but it is not installed
libqtwebkit4:i386 : Depends: libqtcore4:i386 (>= 4:4.8.0~) but it is not installed
libssl1.0.0 : Breaks: libssl1.0.0:i386 (!= 1.0.1-4ubuntu5.2) but 1.0.0e-2ubuntu4.6 is installed
libssl1.0.0:i386 : Breaks: libssl1.0.0 (!= 1.0.0e-2ubuntu4.6) but 1.0.1-4ubuntu5.2 is installed
E: Unmet dependencies. Try using -f.
Using sudo apt-get -f install...
The following packages were automatically installed and are no longer required:
libgtkmm-2.4-1c2a libgtkhtml3.14-19 libglade2-0
Use 'apt-get autoremove' to remove them.
The following extra packages will be installed:
libqtcore4:i386 libssl1.0.0:i386
The following NEW packages will be installed
libqtcore4:i386
The following packages will be upgraded:
libssl1.0.0:i386
1 upgraded, 1 newly installed, 0 to remove and 33 not upgraded.
20 not fully installed or removed.
Need to get 0 B/3,063 kB of archives.
After this operation, 9,044 kB of additional disk space will be used.
Do you want to continue [Y/n]? y
E: Internal Error, No file name for libssl1.0.0
I've tried sudo apt-get remove libssl1.0.0 and sudo apt-get remove libssl1.0.0:i386
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these:
ia32-libs-multiarch:i386 : Depends: libqtcore4:i386 but it is not going to be installed
Depends: libssl1.0.0:i386 but it is not going to be installed
libcurl3:i386 : Depends: libssl1.0.0:i386 (>= 1.0.0) but it is not going to be installed
libqt4-dbus:i386 : Depends: libqtcore4:i386 (= 4:4.8.1-0ubuntu4.1) but it is not going to be installed
libqt4-declarative:i386 : Depends: libqtcore4:i386 (= 4:4.8.1-0ubuntu4.1) but it is not going to be installed
libqt4-designer:i386 : Depends: libqtcore4:i386 (= 4:4.8.1-0ubuntu4.1) but it is not going to be installed
libqt4-network:i386 : Depends: libqtcore4:i386 (= 4:4.8.1-0ubuntu4.1) but it is not going to be installed
libqt4-opengl:i386 : Depends: libqtcore4:i386 (= 4:4.8.1-0ubuntu4.1) but it is not going to be installed
libqt4-qt3support:i386 : Depends: libqtcore4:i386 (= 4:4.8.1-0ubuntu4.1) but it is not going to be installed
libqt4-script:i386 : Depends: libqtcore4:i386 (= 4:4.8.1-0ubuntu4.1) but it is not going to be installed
libqt4-scripttools:i386 : Depends: libqtcore4:i386 (= 4:4.8.1-0ubuntu4.1) but it is not going to be installed
libqt4-sql:i386 : Depends: libqtcore4:i386 (= 4:4.8.1-0ubuntu4.1) but it is not going to be installed
libqt4-sql-mysql:i386 : Depends: libqtcore4:i386 (= 4:4.8.1-0ubuntu4.1) but it is not going to be installed
libqt4-svg:i386 : Depends: libqtcore4:i386 (= 4:4.8.1-0ubuntu4.1) but it is not going to be installed
libqt4-test:i386 : Depends: libqtcore4:i386 (= 4:4.8.1-0ubuntu4.1) but it is not going to be installed
libqt4-xml:i386 : Depends: libqtcore4:i386 (= 4:4.8.1-0ubuntu4.1) but it is not going to be installed
libqt4-xmlpatterns:i386 : Depends: libqtcore4:i386 (= 4:4.8.1-0ubuntu4.1) but it is not going to be installed
libqtgui4:i386 : Depends: libqtcore4:i386 (= 4:4.8.1-0ubuntu4.1) but it is not going to be installed
libqtwebkit4:i386 : Depends: libqtcore4:i386 (>= 4:4.8.0~) but it is not going to be installed
libsasl2-modules:i386 : Depends: libssl1.0.0:i386 (>= 1.0.0) but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
I've also tried sudo apt-get dist-upgrade, sudo apt-get autoremove etc without any luck.
I also tried to download the .deb and use dpkg -i, but that failed and did not fully understand the method to be honest.
Edit This is in response to the comments
ref: sudo apt-get install -f doesn't fix broken packages. And now?
sudo dpkg --configure -a --force-all
dpkg: error processing libssl1.0.0 (--configure):
libssl1.0.0:amd64 1.0.1-4ubuntu5.2 cannot be configured because libssl1.0.0:i386 is in a different version (1.0.0e-2ubuntu4.6)
dpkg: error processing libssl1.0.0:i386 (--configure):
libssl1.0.0:i386 1.0.0e-2ubuntu4.6 cannot be configured because libssl1.0.0:amd64 is in a different version (1.0.1-4ubuntu5.2)
dpkg: also configuring `libssl1.0.0:i386' (required by `ia32-libs-multiarch:i386')
dpkg: too many errors, stopping
libssl1.0.0
libssl1.0.0:i386
libssl1.0.0:i386
Processing was halted because there were too many errors.
Ref: Package manager doesn't work anymore
moving /var/lib/kpkg/info/libssl..
kieran@kieran-EX58-UD3R:~$ sudo mv /var/lib/dpkg/info/libssl1.0.0:i386.postinst /var/lib/dpkg/info/libssl1.0.0:i386.postinst.bad
kieran@kieran-EX58-UD3R:~$ sudo mv /var/lib/dpkg/info/libssl1.0.0:amd64.postinst /var/lib/dpkg/info/libssl1.0.0:amd64.postinst.bad
kieran@kieran-EX58-UD3R:~$ sudo apt-get --reinstall install libssl
Package libssl is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'libssl' has no installation candidate
kieran@kieran-EX58-UD3R:~$ sudo apt-get --reinstall install libssl1.0.0
libssl1.0.0 : Breaks: libssl1.0.0:i386 (!= 1.0.1-4ubuntu5.2) but 1.0.0e-2ubuntu4.6 is to be installed
libssl1.0.0:i386 : Breaks: libssl1.0.0 (!= 1.0.0e-2ubuntu4.6) but 1.0.1-4ubuntu5.2 is to be installed
kieran@kieran-EX58-UD3R:~$ sudo apt-get -f install
Correcting dependencies... Done
libqtcore4:i386
libssl1.0.0:i386
1 upgraded, 1 newly installed, 0 to remove and 58 not upgraded.
Need to get 3,063 kB of archives.
Get:1 http://gb.archive.ubuntu.com/ubuntu/ precise-updates/main libssl1.0.0 i386 1.0.1-4ubuntu5.2 [1,002 kB]
Get:2 http://gb.archive.ubuntu.com/ubuntu/ precise-updates/main libqtcore4 i386 4:4.8.1-0ubuntu4.1 [2,061 kB]
Fetched 3,063 kB in 4s (731 kB/s)
ref: libssl Dependencies removing libssl1.0.0:i386
kieran@kieran-EX58-UD3R:~$ sudo apt-get remove libssl1.0.0:i386
