Is there any solution if I need to mount the directory e.g. /Test pointing to /Opt/Test
Thanks Sumit
Yes, for sure there is!
Easiest option: remove "Test" and replace it by a symbolic link with the same name that links to "/Opt/Test". For practical purposes, such symbolic link behaves and acts as if it were a true directory.
More thorough option: if you have special requirements where a link does not cut it, then you can mount --bind the directory "Test" to "/Opt/Test".
vanadium
  • 97,564
