I have encrypted my disk using LUKS. After every boot up, my machine throws "DISK IS LIKELY TO FAIL SOON" message. To fix this, I am trying to run fsck on the root partition. I tried running fsck in recovery mode but it failed with the following message:
/lib/recovery-mode/recovery-menu: line 80: /etc/default/rcs: No such file or directory
fsck from utli-linux 2.37.2
/dev/mapper/vgubuntu-root is mounted.
e2fsck: Cannot continue, aborting.
So, I tried booting up from a USB and running fsck from there. However, seems like it is not working because I get the following output and fsck terminates immediately:
fsck from util-linux 2.37.2
[/usr/sbin/fsck.ext4 (1) -- /dev/mapper/vgubuntu-root]
fsck.ext4 -y -C0 /dev/mapper/vgubuntu-root
e2fsck 1.46.5 (30-Dec-2021)
/dev/mapper/vgubuntu-root: clean, 1254485/60784640 files, 52105495/243116032 block
Following is the output of lsblk:
NAME        FSTYPE FSVER     LABEL                    UUID                                   FSAVAIL FSUSE% MOUNTPOINTS
/dev/loop0  squash 4.0        0   100% /rofs
/dev/loop1  squash 4.0        0   100% /snap/bare/5
/dev/loop2  squash 4.0        0   100% /snap/firefox/1635
/dev/loop3  squash 4.0        0   100% /snap/gnome-3-38-2004/112
/dev/loop4  squash 4.0        0   100% /snap/gtk-common-themes/1535
/dev/loop5  squash 4.0        0   100% /snap/snapd/16292
/dev/loop6  squash 4.0        0   100% /snap/snap-store/582
/dev/loop7  squash 4.0        0   100% /snap/snapd-desktop-integration/14
/dev/loop8  squash 4.0        0   100% /snap/core20/1587
/dev/sda
├─/dev/sda1 vfat   FAT32                              DFFE-1B40
├─/dev/sda2 ext4   1.0                                b3b523d0-b935-40f1-9bea-f387cf4a4282
└─/dev/sda3 crypto 2                                  80422624-4c6b-4cbb-a969-eb110f60b15e
  └─/dev/mapper/luks-80422624-4c6b-4cbb-a969-eb110f60b15e
            LVM2_m LVM2 001                           iYBO3Z-pyDY-9Yd7-IqGA-CNaq-jFrU-BArfra
    ├─/dev/mapper/vgubuntu-root
    │       ext4   1.0                                123ef630-60c6-45de-a2d2-da21d415b98d
    └─/dev/mapper/vgubuntu-swap_1
            swap   1                                  0bf6ba3c-a03a-4386-9d5a-c5b49765b8d6
/dev/sdb    iso966 Joliet Ex Ubuntu 22.04.1 LTS amd64 2022-08-10-16-21-45-00
├─/dev/sdb1 iso966 Joliet Ex Ubuntu 22.04.1 LTS amd64 2022-08-10-16-21-45-00                       0   100% /cdrom
├─/dev/sdb2 vfat   FAT12     ESP                      8D6C-A9F8
├─/dev/sdb3
└─/dev/sdb4 ext4   1.0       writable                 0498f4be-7be3-4d80-9ffa-53cb6e2797af     49.9G     0% /var/crash
        /var/log
Output of pvdisplay:
  --- Physical volume ---
  PV Name               /dev/mapper/luks-80422624-4c6b-4cbb-a969-eb110f60b15e
  VG Name               vgubuntu
  PV Size               <929.33 GiB / not usable 3.00 MiB
  Allocatable           yes (but full)
  PE Size               4.00 MiB
  Total PE              237907
  Free PE               0
  Allocated PE          237907
  PV UUID               iYBO3Z-pyDY-9Yd7-IqGA-CNaq-jFrU-BArfra
Output of vgdisplay:
  --- Volume group ---
  VG Name               vgubuntu
  System ID
  Format                lvm2
  Metadata Areas        1
  Metadata Sequence No  3
  VG Access             read/write
  VG Status             resizable
  MAX LV                0
  Cur LV                2
  Open LV               0
  Max PV                0
  Cur PV                1
  Act PV                1
  VG Size               929.32 GiB
  PE Size               4.00 MiB
  Total PE              237907
  Alloc PE / Size       237907 / 929.32 GiB
  Free  PE / Size       0 / 0
  VG UUID               zUsuN2-Juyn-1l1V-hyRN-VHbf-dtOh-lyByGZ
Output of lvdisplay:
  --- Logical volume ---
  LV Path                /dev/vgubuntu/root
  LV Name                root
  VG Name                vgubuntu
  LV UUID                2Iwd2Y-VcsI-fhf6-atcw-ijVb-lcsN-Rw3ZS3
  LV Write Access        read/write
  LV Creation host, time ubuntu, 2022-09-16 09:46:16 +0000
  LV Status              available
  # open                 0
  LV Size                927.41 GiB
  Current LE             237418
  Segments               1
  Allocation             inherit
  Read ahead sectors     auto
  - currently set to     256
  Block device           253:1
--- Logical volume --- LV Path /dev/vgubuntu/swap_1 LV Name swap_1 VG Name vgubuntu LV UUID YtYA2H-aKVB-f3bT-Fvi3-m46S-upM1-vWMRwR LV Write Access read/write LV Creation host, time ubuntu, 2022-09-16 09:46:17 +0000 LV Status available
open 0
LV Size 1.91 GiB Current LE 489 Segments 1 Allocation inherit Read ahead sectors auto
  • currently set to 256
Block device 253:2
I have unlocked the disk before running the fsck command.
Why is fsck not running correctly on my machine? What am I missing here?
uname -a output:
Linux ubuntu 5.15.0-43-generic #46-Ubuntu SMP Tue Jul 12 10:30:17 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
lsb_release -a output:
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 22.04.1 LTS
Release:        22.04
Codename:       jammy
