I recently installed ubuntu 22.04 on a new Intel NUC. I created a Fat32 boot partition, and a pv for an LVM with mount points for root, etc, usr...et al. The install went fine and the machine boots. However, there appears to be two bootloaders. I don't know if that's an issue for how the machine works, but I can only modify one of the bootloaders to get rid of the timeout (appears to be the second one). When I look in EFI directory, I see a folder for ubuntu and one for boot - both have boot files in them, but only the ubuntu folder has grub.cfg. I hope this is making sense. Should I remove one of the bootloaders? If not, how do I make the timeouts on both of them zero? If reloading the OS is the answer, that's fine - I don't have a lot on the machine yet, but need to know how to do that without making the same mistake.
EDIT: As requested, output of efibootmgr -v
BootCurrent: 0000
Timeout: 1 seconds
BootOrder: 0000
Boot0000* ubuntu    HD(1,GPT,5871a315-fc5c-4a07-aff3-9c3a34ecc50b,0x800,0x200000)/File(\EFI\UBUNTU\SHIMX64.EFI)
and output of lsblk -f | grep -v loop
NAME            FSTYPE      FSVER    LABEL UUID                                   FSAVAIL FSUSE% MOUNTPOINTS
nvme0n1
├─nvme0n1p1     vfat        FAT32          1544-60B4                              1016.7M     1% /boot/efi
├─nvme0n1p2     swap        1              4f25509f-f6ef-4813-ad42-1e432aecaac0                  [SWAP]
└─nvme0n1p3     LVM2_member LVM2 001       hvwQkX-ARTx-puSH-ZUay-hHhB-HwYk-hMoPYa
  ├─devlvm-root ext4        1.0            f5cf38fb-64ae-442f-9216-fb8fc34be577     29.2G     1% /
  ├─devlvm-home ext4        1.0            64c19ad2-da7e-4e8a-9687-1e0a856328a4     46.5G    20% /home
  ├─devlvm-opt  ext4        1.0            147239ac-2d64-4a6d-8aae-994f299040ca     59.2G     0% /opt
  ├─devlvm-var  ext4        1.0            f54e47d1-9f48-4b9a-afce-5fbb8f1de029       52G    12% /var
  ├─devlvm-srv  ext4        1.0            bf024629-befc-44dd-8fd9-10a667ad514d     59.2G     0% /srv
  └─devlvm-usr  ext4        1.0            66f9426e-a4eb-4f65-8cc9-7e024a8a60c1     52.1G    11% /var/snap/firefox/common/host-hunspell
        /usr
mook765
  • 18,644
phil
