I'm running Ubuntu 20.04.5. Recently all of my system tray application icons (e.g. Dropbox, Discord) disappeared, and restarting did not help. When I run Dropbox or Discord from terminal, their outputs both include the following error (among a lot of other output):
libappindicator-WARNING **: 17:17:54.679: Unable to connect to the Notification Watcher: GDBus.Error:org.gnome.gjs.JSError.ValueError: domain.replaceAll is not a function
Similarly, when I run OBS or Talon (dictation software) from terminal, I get a related error:
QDBusTrayIcon encountered a D-Bus error: QDBusError("org.gnome.gjs.JSError.ValueError", "domain.replaceAll is not a function")
These programs all run normally otherwise, but I really want the tray icons back because some functionality can only be accessed from there. I searched up these errors but couldn't find anything useful.
Things that could have triggered this: the Software Updater recently updated some software, but I didn't pay attention to what was updated. Also, I only recently installed Talon. Both were shortly before the tray icons disappeared. I also use a GNOME extension/tweak called Icon Hider to hide some system tray icons, but I have been using that for months with no problems. Enabling and disabling the extension also did not solve the problem.
Does anyone know what might be causing this or how I can fix it?
rayna
  • 113
This seems to be fixed here:
https://github.com/ubuntu/gnome-shell-extension-appindicator/commit/5ebb018e7b2d0219d3cf25c69f5d988b7a53121b
You can manually apply this fix in ~/.local/share/gnome-shell/extensions/appindicatorsupport@rgcjonas.gmail.com/util.js by changing this line (about 470)
Logger._domain = domain.replaceAll(' ', '-');
to
Logger._domain = domain.replaceAll ? domain.replaceAll(' ', '-')
    : domain.split(' ').join('-');
Under X11, you may need to restart GNOME Shell (Alt+F2, r, ⏎) after that. Under Wayland you need to logout and login again.
Doing this fixed the problem for me until a new version is released.
Same version 20.4.5 LTS, same issue
All my tray application icons disappeared after an update a few weeks ago.
I'm not using Talon or the extension "Icon Hider"
This is the error I'm seeing with "diodon", a clipboard manager :
(diodon:3931): libappindicator-WARNING **: 15:08:25.977: Unable to connect to the Notification Watcher: GDBus.Error:org.gnome.gjs.JSError.ValueError: domain.replaceAll is not a function
ericc
  • 121
I had a similar problem in Zorin OS Core 16.2 (Ubuntu 20.04) and solved in 2 steps. First, install gnome-shell-extension-appindicator via terminal (sudo apt install gnome-shell-extension-appindicator). And, finally, install the extension AppIndicator and KStatusNotifierItem Support by 3v1n0 (AppIndicator and KStatusNotifierItem Support - GNOME Shell Extensions). Reference: how to use a tray icon. That's it. And if you also want minimize any program to the system tray, you can install the program called Kdocker (but it is still required doing the 2 steps mentioned before).
