I'm trying to set up a couple of VM's with KVM/Qemu. They are supposed to be on the same network as the host. I have tried out a couple of guides found on the internet but to no avail.
Will someone please tell me how to do it?
Best regards
Artur Meinild
  • 31,035
I have done this setup, and it worked before I restarted the host machine. So technically it's correct. Please try this and see if it works for you.
Essentially it boils down to this:
  1. Create a bridge using nm-connection-editor.
  2. Join the network interface on the host to the bridge.
  3. Remove the existing libvirt network and create a new one using this bridge as basis
  4. Select "Virtual network: bridged network" in the Virtual Machine Manager guest config or use the quivalent cli commands.
The bridge becomes invisible to the guest and host.
LifeBoy
  • 2,392
