-Hi I'm trying to install ns3.34 in ubuntu in VMware workstation pro and when I typed the command :
$ sudo apt install g++ python3 python3-dev \
python-dev pkg-config sqlite3 python3-setuptools git qt5-default \
gir1.2-goocanvas-2.0 python3-gi python3-gi-cairo python3-pygraphviz \
gir1.2-gtk-3.0 ipython3 openmpi-bin \
openmpi-common openmpi-doc libopenmpi-dev autoconf cvs bzr \
unrar openmpi-bin openmpi-common openmpi-doc \
libopenmpi-dev tcpdump wireshark libxml2 libxml2-dev.
  • It got error like this :
Reading package lists... Done
Building dependency tree... Done
Package python-dev is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
However the following packages replace it:
  python2-dev:i386 python2:i386 python2-dev python2 python-dev-is-python3
Package qt5-default is not available, but is referred to by another package. This may mean that the package is missing, has been obsoleted, or is only available from another source
E: Package 'python-dev' has no installation candidate E: Package 'qt5-default' has no installation candidate
  • Can someone help me fix this error? I'm sorry in advance if my grammar and question are wrong somewhere, it's my first time learning about ns3 and virtual machines.
waltinator
  • 37,856
You must be following some old tutorial, which is now out of date.
  1. Use python3-dev instead of python-dev.
  2. According to https://bugs.launchpad.net/ubuntu/+source/qtbase-opensource-src/+bug/1926802, you don't anymore need qt5-default in recent versions of Ubuntu, as version 5 of Qt is the default version (Qt4 is now obsolete). You can simply remove it from the list of packages. If you need to install development packages for qt, run
sudo apt-get install qtbase5-dev qtchooser qt5-qmake qtbase5-dev-tools
