Hardware Context
  • Nvidia GeForce 960
  • Intel i9 11900K
  • ASUS TUF GAMING B60M-PLUS
(I think that the only relevant spec is GPU)
Problem
Hi. I've recently upgraded from Ubuntu 22.04 to Ubuntu 22.10. A few days passed without major problems, but today I booted into Ubuntu (have dual boot with Windows 11, which is working without any problem) and ended up in emergency mode with following message:
/dev/nvme0n1p5: recovering journal
/dev/nvme0n1p5: clean, 1484190/15171584 files, 18827904/60659968 blocks
[     3.712179] hdaudio hdaudioC0D2L Unable to configura, disabling
[     3.712285] nouveau 0000:01:00.0: bus: MMIO write of 80000140 FAULT at 10eb14
 [ PRIVRING ]
You are in emergency mode. After logging in, type "journalctl -xb" to view
system logs, "systemctl reboot" to reboot, "systemctl default" or "exit"
to boot into default mode.
Press Enter for maintenance
(or press Control-D to continue):
First try
After some googling I decided to blacklist nouveau drivers adding to /etc/modprobe.d/blacklist.conf:
blacklist nouveau
options nouveau modeset=0
Then running update-initramfs -u and reboot.
Message changed to the following but still not booting into graphic desktop. Fun fact is that font changed to a more stylized one, I think that Ubuntu's terminal default font.
[     3.590755] hdaudio hdaudioC0D2L Unable to configure, disabling
[     5.156330] Bluetooth: hci0: Malformed MSFT vendor event: 0x02
Press Enter formaintenance
After that, I tried to install nvidia propietary drivers from ubuntu repositories doing apt-get install nvidia-drivers-515, but at the end of the installation, terminal freezes for say 2 minutes and then prompts again with "emergency mode". Nvidia drivers are not installed: dpkg -l shows nothing about nvidia and I can run apt-get install nvidia-drivers-515 again with the exact same result. The same happens with any apt-get or apt command, even update. This already happened before blacklisting nouveau.
I've downloaded drivers from Nvidia site, but I don't know if use it, because when I run it, it shows a warning which says that is better to use distribution packages.
Third shot (UPDATE)
Followed Nmath suggestion and ran ubuntu-drivers autoinstall which installed nvidia drivers. After reboot, I still get into emergency mode, but with a slightly different message: no Bluetooth fail.
[     3.602462] hdaudio hdaudioC0D2L Unable to configure, disabling
[     3.672505]
Note the blank line under hdaudio and befor "Emergency mode" prompt.
The problem was /boot/efi entry in /etc/fstab, it was broken, maybe some upgrade messed it up. I don't know if nouveau drivers were the problem at the begining or I was just missleading. Closing this.
