I am trying to install odoo v12 in Ubuntu 22.04 using venv with python3.6. This is what I have done so far.
I installed python3.6 using the following tutorial. [How to install python3.6 on Ubuntu 22.04][1] [1]: https://stackoverflow.com/questions/72102435/how-to-install-python3-6-on-ubuntu-22-04
which python3.6
/usr/local/bin/python3.6
I created an environment using the previous installed version of python
/usr/local/bin/python3.6 -m venv ./odoo12/
I activated the environment and installed all requirements of odoo successfully. Without showing any error.
I run the odoo-bin inside the virtual environment
python3 odoo-bin --addons-path="./addons" -d odoo12 python3 odoo-bin --addons-path="./addons" -d odoo12 It runs, but showing some warnings,
2022-10-25 22:38:36,196 6987 WARNING ? py.warnings: /home/ernesto/Programming/odoo12/odoo/http.py:1334: ResourceWarning: unclosed file <_io.BufferedReader name='/home/ernesto/Programming/odoo12/odoo/addons/test_new_api/manifest.py'> manifest_data = open(manifest_path, 'rb').read()
and when I open the browser and type http://127.0.0.1:8069/web/login the server stops, and shows an error
python3: Python/compile.c:3021: compiler_nameop: Assertion `!_PyUnicode_EqualToASCIIString(name, "None") && !_PyUnicode_EqualToASCIIString(name, "True") && !_PyUnicode_EqualToASCIIString(name, "False")' failed.
Aborted (core dumped)
Whats is causing those errors, and how can I install odoo v12 in Ubuntu 22.04 [1]: https://stackoverflow.com/questions/72102435/how-to-install-python3-6-on-ubuntu-22-04
