On a freshly installed Ubuntu 22.04 machine I am trying to install libgstreamer-plugins-base1.0-dev package. First I ran sudo apt update && sudo apt full-upgrade, then:
$ sudo apt sudo apt install libgstreamer-plugins-base1.0-dev
Reading package lists... Done
Building dependency tree... Done
libgbm-dev : Depends: libgbm1 (= 22.0.1-1ubuntu2) but 22.0.5-0ubuntu0.1 is to be installed
libudev-dev : Depends: libudev1 (= 249.11-0ubuntu3) but 249.11-0ubuntu3.6 is to be installed
Now if I try to manually install the dependencies:
$ sudo apt install libgbm1
libgbm1 is already the newest version (22.0.5-0ubuntu0.1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Also, manually installing the requested version would remove a lot of already installed packages, which is not what I want:
$ sudo apt install libgbm1=22.0.1-1ubuntu2
The following packages were automatically installed and are no longer required:
apg apturl-common cheese-common dctrl-tools dkms docbook-xml evolution-data-server-common gir1.2-accountsservice-1.0 gir1.2-adw-1 gir1.2-dbusmenu-glib-0.4
gir1.2-dee-1.0 gir1.2-gck-1 gir1.2-gcr-3 gir1.2-gdm-1.0 gir1.2-geoclue-2.0 gir1.2-gnomebluetooth-3.0 gir1.2-graphene-1.0 gir1.2-gtk-4.0 gir1.2-gweather-3.0
gir1.2-javascriptcoregtk-4.0 gir1.2-json-1.0 gir1.2-nm-1.0 gir1.2-nma-1.0 gir1.2-rsvg-2.0 gir1.2-soup-2.4 gir1.2-unity-7.0 gir1.2-upowerglib-1.0 gkbd-capplet
gnome-bluetooth-3-common gnome-control-center-faces gnome-session-common gnome-shell-common gstreamer1.0-pipewire gstreamer1.0-plugins-ugly i965-va-driver
imagemagick-6-common intel-media-va-driver liba52-0.7.4 libabsl20210324 libaom3 libass9 libatomic1:i386 libavcodec58 libavutil56 libayatana-appindicator3-1
libayatana-ido3-0.4-0 libayatana-indicator3-7 libbs2b0 libbsd0:i386 libcamel-1.2-63 libchromaprint1 libclutter-1.0-common libcodec2-1.0 libcogl-common
libcolord-gtk1 libdav1d5 libdbusmenu-gtk3-4 libdc1394-25 libdca0 libde265-0 libdecor-0-0 libdecor-0-plugin-1-cairo libdouble-conversion3 libdrm-amdgpu1:i386
libdrm-nouveau2:i386 libdrm-radeon1:i386 libdrm2:i386 libdvdnav4 libdvdread8 libebackend-1.2-10 libebook-1.2-20 libebook-contacts-1.2-3 libecal-2.0-1
libedata-book-1.2-26 libedata-cal-2.0-1 libedataserver-1.2-26 libedit2:i386 libelf1:i386 libexpat1:i386 libfaad2 libffi8:i386 libfftw3-double3 libflite1
libfluidsynth3 libfreeaptx0 libfreerdp-client2-2 libfreerdp-server2-2 libfreerdp2-2 libgdm1 libgl-dev libgl1:i386 libgl1-mesa-dri:i386 libglapi-mesa:i386 libgles2
libglu1-mesa libglu1-mesa-dev libglvnd0:i386 libglx-dev libglx-mesa0:i386 libglx0:i386 libgme0 libgnome-bluetooth-3.0-13 libgnomekbd-common libgnomekbd8 libgsm1
libgsound0 libgssdp-1.2-0 libgstreamer-plugins-bad1.0-0 libgupnp-1.2-1 libgupnp-av-1.0-3 libgupnp-dlna-2.0-4 libgupnp-igd-1.0-4 libharfbuzz-icu0 libheif1 libhyphen0
libicu70:i386 libigdgmm12 libilmbase25 libinput-bin libinput10 libinstpatch-1.0-2 libjavascriptcoregtk-4.0-18 libjxr-tools libjxr0 libkate1 libldacbt-enc2
liblilv-0-0 libllvm13:i386 liblqr-1-0 libltc11 libmagickcore-6.q16-6 libmagickcore-6.q16-6-extra libmagickwand-6.q16-6 libmanette-0.2-0 libmd0:i386 libmd4c0
libmediaart-2.0-0 libmfx1 libmjpegutils-2.1-0 libmodplug1 libmpcdec6 libmpeg2-4 libmpeg2encpp-2.1-0 libmplex2-2.1-0 libmtdev1 libnice10 libnvidia-cfg1-515
libnvidia-common-515 libnvidia-compute-515:i386 libnvidia-decode-515 libnvidia-decode-515:i386 libnvidia-egl-wayland1 libnvidia-encode-515 libnvidia-encode-515:i386
libnvidia-extra-515 libnvidia-fbc1-515 libnvidia-fbc1-515:i386 libnvidia-gl-515:i386 libopenal-data libopenal1 libopencore-amrnb0 libopencore-amrwb0 libopenexr25
libopengl0 libopenh264-6 libopenmpt0 libopenni2-0 libphonenumber8 libprotobuf23 libpthread-stubs0-dev libqrencode4 libqt5concurrent5 libqt5core5a libqt5dbus5
libqt5network5 libqt5sql5 libqt5sql5-sqlite libqt5test5 libqt5xml5 librest-0.7-0 librygel-core-2.6-2 librygel-db-2.6-2 librygel-renderer-2.6-2 librygel-server-2.6-2
libsdl2-2.0-0 libsensors5:i386 libserd-0-0 libshine3 libsidplay1v5 libsnappy1v5 libsndio7.0 libsord-0-0 libsoundtouch1 libsoup-gnome2.4-1 libspandsp2 libsratom-0-0
libsrt1.4-gnutls libsrtp2-1 libstdc++6:i386 libswresample3 libsysmetrics1 libva-drm2 libva-x11-2 libva2 libvdpau1 libvncserver1 libvo-aacenc0 libvo-amrwbenc0
libvulkan-dev libvulkan1:i386 libwayland-client0:i386 libwildmidi2 libwinpr2-2 libwoff1 libx11-6:i386 libx11-dev libx11-xcb1:i386 libx264-163 libx265-199
libxatracker2 libxau-dev libxau6:i386 libxcb-dri2-0:i386 libxcb-dri3-0:i386 libxcb-glx0:i386 libxcb-icccm4 libxcb-image0 libxcb-keysyms1 libxcb-present0:i386
libxcb-randr0:i386 libxcb-render-util0 libxcb-res0 libxcb-shm0:i386 libxcb-sync1:i386 libxcb-xfixes0:i386 libxcb-xinerama0 libxcb-xinput0 libxcb-xkb1 libxcb-xv0
libxcb1:i386 libxcb1-dev libxcvt0 libxdmcp-dev libxdmcp6:i386 libxext-dev libxext6:i386 libxfixes3:i386 libxfont2 libxkbcommon-x11-0 libxklavier16 libxml2:i386
libxnvctrl0 libxshmfence1:i386 libxslt1.1 libxss1 libxvidcore4 libxvmc1 libxxf86vm1:i386 libzbar0 libzvbi-common libzvbi0 libzxingcore1 mesa-va-drivers
mesa-vdpau-drivers mesa-vulkan-drivers:i386 mobile-broadband-provider-info mutter-common network-manager-gnome nvidia-compute-utils-515 nvidia-dkms-515
nvidia-kernel-common-515 nvidia-kernel-source-515 nvidia-prime nvidia-settings ocl-icd-libopencl1 policykit-1-gnome power-profiles-daemon python3-debconf
python3-debian python3-macaroonbakery python3-nacl python3-protobuf python3-pymacaroons python3-rfc3339 qt5-qmake qt5-qmake-bin qtbase5-dev-tools qtchooser
qttranslations5-l10n rygel screen-resolution-extra sgml-data switcheroo-control timgm6mb-soundfont update-notifier-common va-driver-all vdpau-driver-all x11-apps
x11-session-utils x11-xkb-utils x11proto-dev xbitmaps xcvt xdg-dbus-proxy xfonts-base xfonts-encodings xfonts-scalable xfonts-utils xinit xinput xorg-sgml-doctools
xserver-common xserver-xephyr xserver-xorg-legacy xtrans-dev xwayland yelp-xsl zenity-common
Use 'sudo apt autoremove' to remove them.
The following additional packages will be installed:
policykit-1-gnome
The following packages will be REMOVED:
apturl evolution-data-server gdm3 gir1.2-mutter-10 gir1.2-webkit2-4.0 gnome-control-center gnome-initial-setup gnome-online-accounts gnome-remote-desktop
gnome-session-bin gnome-shell gnome-shell-extension-appindicator gnome-shell-extension-desktop-icons-ng gnome-shell-extension-ubuntu-dock gnome-startup-applications
gnome-user-docs gstreamer1.0-clutter-3.0 gstreamer1.0-gl gstreamer1.0-plugins-bad libcheese-gtk25 libcheese8 libclutter-1.0-0 libclutter-gst-3.0-0
libclutter-gtk-1.0-0 libcogl-pango20 libcogl-path20 libcogl20 libedataserverui-1.2-3 libegl-dev libegl-mesa0 libegl1 libgoa-backend-1.0-1 libgstreamer-gl1.0-0
libmutter-10-0 libnvidia-gl-515 libqt5gui5 libqt5opengl5 libqt5opengl5-dev libqt5printsupport5 libqt5svg5 libqt5widgets5 libwebkit2gtk-4.0-37 libyelp0
nautilus-share nvidia-driver-515 qt5-gtk-platformtheme qtbase5-dev ubuntu-desktop ubuntu-desktop-minimal ubuntu-docs ubuntu-release-upgrader-gtk ubuntu-session
update-manager update-notifier xorg xserver-xorg xserver-xorg-core xserver-xorg-input-all xserver-xorg-input-libinput xserver-xorg-input-wacom
xserver-xorg-video-all xserver-xorg-video-amdgpu xserver-xorg-video-ati xserver-xorg-video-fbdev xserver-xorg-video-intel xserver-xorg-video-nouveau
xserver-xorg-video-nvidia-515 xserver-xorg-video-qxl xserver-xorg-video-radeon xserver-xorg-video-vesa xserver-xorg-video-vmware yelp zenity
The following NEW packages will be installed:
policykit-1-gnome
The following packages will be DOWNGRADED:
libgbm1
0 upgraded, 1 newly installed, 1 downgraded, 73 to remove and 0 not upgraded.
Here my apt sources:
$ cat /etc/apt/sources.list /etc/apt/sources.list.d/*.list | grep -v ^#
cat: '/etc/apt/sources.list.d/*.list': No such file or directory
deb http://at.archive.ubuntu.com/ubuntu/ jammy main restricted
deb http://at.archive.ubuntu.com/ubuntu/ jammy universe
deb http://at.archive.ubuntu.com/ubuntu/ jammy multiverse
deb http://security.ubuntu.com/ubuntu jammy-security restricted main
deb http://security.ubuntu.com/ubuntu jammy-security universe
deb http://security.ubuntu.com/ubuntu jammy-security multiverse
And here the update output:
$ sudo apt upgrade
Calculating upgrade... Done
Try Ubuntu Pro beta with a free personal subscription on up to 5 machines.
Learn more at https://ubuntu.com/pro
$ sudo apt update
Hit:1 http://at.archive.ubuntu.com/ubuntu jammy InRelease
Hit:2 http://security.ubuntu.com/ubuntu jammy-security InRelease
All packages are up to date.
So how can I fix this dependency problem?
