63
I want to mount a partition to an auxiliary folder via mount to fix a damaged grub.
I used the command.
sudo mount /dev/sdb2 /home/ubuntu/temp
and got as error:
mount: you must specify the filesystem type
Why?
andandandand
  • 1,269
6 Answers6
60
You need to add the -t FILESYSTEMTYPE argument to the command, replacing FILESYSTEMTYPE with your filesystem type. This specifies the filesystem type of the filesystem to be mounted. In your case, this would be /dev/sdb2. Some common, valid filesystem types are:
  • auto - this is a special one. It will try to guess the fs type when you use this.
  • ext4 - this is probably the most common Linux fs type of the last few years
  • ext3 - this is the most common Linux fs type from a couple years back
  • ntfs - this is the most common Windows fs type or larger external hard drives
  • vfat - this is the most common fs type used for smaller external hard drives
  • exfat - is also a file system option commonly found on USB flash drives and other external drives
reverendj1
  • 16,403
15
I was getting a similar error:
# mount /dev/sdb1 /mydisk/ -t auto
I tried finding out the issue and the issue was, I had partitioned it but no filesystem was assigned.
# mkfs.ext3 /dev/sdb1 2>/dev/null
Superblock backups stored on blocks:
Writing inode tables: done
Creating journal (32768 blocks): done
Writing superblocks and filesystem accounting information: done
This filesystem will be automatically checked every 39 mounts or
180 days, whichever comes first.  Use tune2fs -c or -i to override
After this it successfully got mounted.
Eliah Kagan
  • 119,640
Ankzz
  • 159
There is more to the story here. Usually if you mount a partition with a common filesystem type using mount, it will auto-detect the partition type.
The fact that it isn't auto-detecting it in this case could signal a few possibilities.
  • You haven't installed filesystem tools for the chosen filesystem. If you did a standard desktop install of Ubuntu, this shouldn't normally be a problem.
    For example, to mount ntfs drives in recent versions of Ubuntu you need the ntfs-3g package.
  • You selected the wrong partition.
  • The partition is corrupt or unformatted. In this case, you should probably do a filesystem check (fsck) on it before mounting it. You may then want to proceed to mount it manually, specifying the filesystem type, as read-only. If all else fails you may need special recovery software such as testdisk photorec.
thomasrutter
  • 37,804
Please use parted -l to check the partition type and make sure you are mounting an actual data partition with known partition types (for example, ntfs, fat, etc).
Here is what you would see from an 8TB drive, the first partition is not the actual data partition and instead, you should mount the second partition, which is the actual data partition.
Model: TRUSTED Mass Storage (scsi)
Disk /dev/sdb: 8796GB
Sector size (logical/physical): 512B/512B
Partition Table: gpt
Number  Start   End     Size    File system  Name                          Flags
1      17.4kB  134MB   134MB                Microsoft reserved partition msftr        `                    es
2      134MB   8796GB  8796GB  ntfs         Basic data partition
Pabi
  • 7,429
AZhu
  • 161
If you have a > 32 GB drive usable on Windows and/or Mac that is not NTFS, and that is what you try to mount, chances are that you are trying to mount an exfat drive.
For that to work, you need to install exfat-utils (and exfat_fuse that will automatically be installed as a dependency).
You can check the filesystem type by file command:
file -sL /dev/sd*
The usage of -s is explained in file - Linux/Unix command and here is an excerpt:
"This is useful for determining the filesystem types of the data in raw disk partitions, which are block special files."
Besides, I mounted successfully without specifying -t type.
Clara
