I wrote a Shell script and named it " process.sh ".
I sent the script to my friend. I am curious if there is a way that he can run the script directly without using chmod +x process.sh. For example, he can directly run ./process.sh after downloading the script.
Do I need to set anything for my script?
Thank you for your help.
Asked
Active
Viewed 806 times
Gongq
- 13
chmod +x makes the script executable.
Without it, the file is not executable, and can't be run.
Nmath
- 12,664
It depends on how you "send" the script. If the file permissions are preserved, your friend will be able to run it directly. If not, then the executable bit needs to be set.
As an email attachment, permissions and ownerships are not preserved. Included in for example a .tar archive, permissions are preserved when extracting the archive. When using info-zip to create a zip file, permissions also can be preserved.
vanadium
- 97,564
