I just upgraded to Kubuntu 22.10, the update was successful completely minus FFmpeg.
Things I've tried:
- Install an older FFmpeg from Ubuntu sources
- Install master FFmpeg from source
- Install FFmpeg 5.1.2 from source
- Install FFmpeg 5.0.1 from source
- Install older libav stuff from Ubuntu sources
- Reinstall current FFmpeg from Ubuntu sources
- Reinstall
libva2from Ubuntu sources - Reinstall
libva2andlibva-utilsfrom GitHub (as per this post)
This always results in the same thing:
ffmpeg: symbol lookup error: /lib/x86_64-linux-gnu/libavcodec.so.59: undefined symbol: vaSyncBuffer
It seems as if some other dependency of FFmpeg is calling libavcodec59 and is having issues with it
Things I cannot do:
- Uninstall
libva2, as it will uninstall my desktop environment - Revert to an
libva2=2.14.0-1, same dependency issue with my DE
From what I have gathered, this appears to be an issue with libva, some dependency from FFmpeg requires libva>=2.16, but the Ubuntu sources don't have that version yet and that dependency doesn't state that requirement
I do have some amdgpu drivers installed, so let me know if you need to know more about them.
Update
I did some more searching, and this is the output from vainfo:
libva info: VA-API version 1.8.0
libva info: Trying to open /opt/amdgpu/lib/x86_64-linux-gnu/dri/iHD_drv_video.so
libva info: va_openDriver() returns -1
libva info: Trying to open /opt/amdgpu/lib/x86_64-linux-gnu/dri/i965_drv_video.so
vaInitialize failed with error code -1 (unknown libva error),exit
So I'll be researching more into the amdgpu drivers, as I've had issues with those before
Versions:
Ubuntu - 22.10 Kinetic Kudu (Kubuntu)
kernel - 5.19.0-23-generic
libva2 - 2.15.0-1 (Ubuntu source)
FFmpeg - 5.1.1-1ubuntu1 (irrelevant in this case)
libva2 - 2.16 (GitHub, possible installation failure)
FFmpeg - 5.1.2 (git, no change)
FFmpeg - 5.0.2 (git, no change)
FFmpeg - 4.4.2-0ubuntu0.22.04.1 (Ubuntu sources, no change)
Reinstalling the various libav stuff from where ever did not change anything either
