-1
I am trying to dual boot my machine. Machine has a 128gb ssd and 1TB HDD. I gave 100 gbs of HDD for Windows(As i use it rarely). For ubuntu 20.04,(which i am installing. Not yet installed) i am giving 60GB for root. 10GB for swap 54GB for home. I want to know under which file system and what mount point should i mount my HDD(1TB rem 900gbs) so that later i can symlink my home's subdirectories i.e downloads, docs, music, etc to my HDD. So as to ensure bigger storage space. I want to know
  1. Which partitioning scheme for the HDD i. Logical or physical
  2. File system for my HDD partition eg Ext4, Ext3 or FAT32
  3. Mount Point i should create for it(if anything in specific)
Note: I am currently installing and am not done installing yet.
samrat
It is fully your call. You decide upon that. Once it is mounted automatically during startup, you will be able to create symlinks to that storage.
There is even no strong convention on where to store such volume.
  • You could mount it in a directory under /media. In that case, by default, the volume will be shown as an icon in the left pane of the file manager.
  • You could mount it under your custom directory, e.g. /data.
To mount a partition stored on an internal disk automatically during startup, first create the desired mount point (i.e., the directory in which the contents of the partition will appear once mounted). Then you can use the utility "Disks" to configure the mount:
  • Click the partition in the map, then the gear icon: select "Edit mount options").
  • Uncheck the switch "User Session Defaults".
  • Check "Mount at system startup", for "Mount Point" provide the full path name to your existing mount point (e.g. /media/my_drive or /data/my_drive).
  • For "Filesystem Type", provide the filesystem used on the disk, e.g. ext4 or ntfs. You can see the file system of your partitions in the output of lsblk -f.
Seasoned linux users typically will directly edit the configuration file /etc/fstab instead.
vanadium
  • 97,564
