After I installed Picasa 3.9, I tried to import some photos from a USB stick plugged in. However, it does not show up in Picasa (Ubuntu has no problem recognizing it). There is just a general Mass Storage Camera item in the Import From field. When I select it, the program hangs. Could it be caused by this bug? Do you know any workaround?
In the Import From field, try to select the "Folder" item and then choose the mounting point where your USB stick is connected by Ubuntu, then you will be able to import your photos.
